Brake Light Switch
txgmc
I need to change the switch on my 05 Z71. I can see it and I can see the plug, but how in the world do I get that clip off and get easier access to the switch itself? Any help would be greatly appreciated! Thanks in advance.
Z-56 Hoe
What do I do????
Houston
Remove the bezel and have your key in to do that so you can drop it down to 1st gear so it will pull out smoothly.
T
txgmc
Thanks! Any help on how to get the clip off of the switch?
T
txgmc
The clip put up a little bit of a fight since I couldn't really see how the clip worked, but I was able to get it. Thanks.
chacho44
MOTORCITY
I think mine is goin bad on my escalade. Turn signals, hazaeds work fine. No brk lights though, this sou d like the switch?
T
txgmc
That was pretty much the same symptoms I had except my brake lights worked intermittently. Now they seem to be working like they should be.
zieglerj-pdm-specialist
in 100 degree sandbox
Which Tahoe is the womens and which is the alpha males.
---------- Post added at 11:28 AM ---------- Previous post was at 11:22 AM ----------
Which Tahoe is the womens and which is Man's Tahoe??.
AdrienR
