Did the Denali ever come with heated wind shield wiper fluid?
Ponchonutty
New Washington, Ohio
Just curious if any of these trucks had that option and if so, where was the button located? I know GM had a campaign deleting this option since they blamed the units for catching vehicles on fire.
NathanJax
Vacation Nathan
Jax, Fl
yes, it would be under your a/c controls on your dash...
If you press it, nothing happens (if the recall has been done)
TowGMC
Wheaton, IL
'07 & '08 Denali had them, and as Nathanjax said, the dealers were required to remove them whether you wanted it deleted or not. Several friends who had them removed were able to go to the original manufacturer and get the updated parts to reinstall. But one friend's dealer removed that too thinking it was factory, and had to pay to have the aftermarket part put back in since they'd destroyed the part they'd removed per GM orders. But there's no retrofit kit for those of us with newer Denalis, at least that I'm aware of.
Ponchonutty
Ponchonutty
Is the newer unit worth the cost?
Yes it was for me on my Saturn Outlook. I had the dealer do the recall and with the money they paid me do remove it I bought a new one from the manufacturer. Unfortunately I don't have that button on my Denali. I do how ever have one extra heater wiper module :) I may just pull that panel apart to see if it's prewired. May get lucky but I doubt it.
doubletapdrew
We carry the Alphatherm units for folks that wanted it and had their stock units removed. I put it in my 07 after the recall. Its handy for getting dried/sticky crud off the windshield and for defrosting it quickly.
yOGi420
What is the typical cost of the retro? Just trying to figure if it's worth doing.
felixgun
Lafayette, LA
^^^It's like $100. When you get your old one removed they cut you a check for $100. Then the alphatherm unit cost the same. I did all this on my 08 tahoe.
Ponchonutty
Ponchonutty
Back when the recalls were going through I bought bunch of them and was re-installing them on recalled vehicles at $85 installed. I had one laying on the shelf that I found. The good news is that I have the heated button :) Had the new unit installed in 15 minutes and working as it should :)
scottg918514
Bought my '07 Yuk XL Denali this year, I was looking fwd to heated washer fluid this winter. After reading this post I went out and checked. Unit, fuse is removed, damn.
I bought the AlphaTherm replacement direct for $80 shipped. Not bad, looks like a 15 min install.
08grey
Brought one on eBay yest for 67 bucks. Can't wait.
Ponchonutty
Ponchonutty
When I bought the batch I had new from my supplier they cost about $40 each!!!! AlphaTherm still stands behind their product and swears the "fire" issues GM had wasn't on their end. The units GM used were designed by AlphaTherm but not to AlphaTherms specs.
PeteKT
My 08 Escalade had this, the dealer removed it and i went to the company who made them since they were about 5 minutes from my house, and they installed a brand new one which was plug and play right into the old ones spot, GM even left the 60amp fuse in the fuse box so i didnt have to buy one.
Best feature ever, was amazing in the winter with the snow, im gonna miss it though.
scottg918514
MicroHeat was original manu, the unit was called the HotShot. They went bust after losing GM contract. However, AlphaTherm started up after "acquiring" the designs (might even be the same folks), their unit is called the HeatShot.
Supposedly, they enhanced the design to better work with GM electrics.
My unit is on it way. BTW, does anyone know if the AlphaTherm unit comes with a 60amp fuse to replace the dealer removed one?
jstutz101
Kankakee, Il
If you purchased it from their web site they have a "Buy with fuse" option. I suspect it dosent come with one.
scottg918514
Got unit from AlphaTherm yesterday, installed today. No real issues, works great. Did have to get 60 amp fuse, dealer must have removed that also. The dealer also bent the bracket that holds the unit when they removed it. That was my only install issue, needed the bend the top flange down so the unit would snap in.
08grey
I got my unit today but when I went to install I realized the dealer must have removed the bracket during the recall because I have no bracket. Now I have to find one.
Word of advise check your truck and make sure you have the bracket before you buy.
Conedaddy
