cheap 3 inch lift
ll0scrappy0ll
I have a 97 yukon 4dr 4x4. What's the cheapest way I can lift it 3 inches and what's the biggest tire I can put under it?
Gzes
the drifting 2dr
Wichita tx
You can crank and put blocks on the back bu it hurts everything else in regards to wear life . Do a body lift. Cheap and easy to do. You can snug some 35s but will have to trim. I am gonna put military 36s on mine and have 3in body and gonna do a lil bit more lift to fit them
L
ll0scrappy0ll
Are there any springs or leaf springs that I can get off another truck that would lift my?
Gzes
the drifting 2dr
Wichita tx
No. Maybe off of a 1 ton but not worth it. You can get add a leaf an raise a lil bit but body lift is cheapest for the height. 3 in for under $200 and won't wear out suspension like a crank
BakermanINC
Bennettsville, SC
You got a link or a suggestion for a 3" body kit for that price? I can't find anything.
Sent from my DROID BIONIC using Tapatalk 2
saif najd
I think it is point less to do the body lift! I need to see some pictures of the result .. could any please post some pictures?
I need to lift my 2dr a 2in or 3, but I can't find the best method!
clownracer
like Gzes said if your 3" or under just do the body lift and stuff some big tires under there
3" BL 35" tires he didnt even have to trim.....looks amazing
Gzes
the drifting 2dr
Wichita tx
Welcome back bowtie havnt seen you in a while. Op here's my hoe wih body lift
Qatar83
qatar
Very nice car pls what size and brand of wheel and that only boady lift with out crank the bar and pls whats the tire size tnx allllot
veteran111
