service history from vin#?
fiercecivic
I just purchased a 2009 yukon slt, I am wondering if it is possible to check service records from the past to see what has been done to the vehicle at deakerships. Does anyone know if this is possible?
Vin# 1GKFK33099R103187
mfdrookie516
Loading.......
Carfax and the like will usually list information about this, but it's only as accurate as the information that they're provided. Many people, like myself, prefer to fix things on their own rather than pay someone (especially a dealership). Also, a lot of shops don't sell information to carfax, so just because it doesn't say something doesn't mean it hasn't happened. You can likely have a dealership check your vin for past warranty work, but I'm not sure if they retain info on other repairs or not.
TheFuzz
Idiot Police
Spurbury, VT
GM has an owner's website that you can sign up for. Once you enter your VIN, you can check the service history. However, much like Carfax, it will only list what has been entered by any previous owners. I don't think that the dealerships update the records themselves. My Carfax report has tons of service history listed on it, while the GM owner's website had none.
Worth a shot though. https://my.gm.com
F
fiercecivic
I have the carproof report that came with the vehicle, but i dont see any service history on report. Are carproof and carfax different databases?
doubletapdrew
Here's what GM has on it:
Transaction History View Details
Job Card Date Job Card Number Transaction Type Transaction Adjustment Labour Operation Odometer Reading
05/21/2013 355136 ZREG----Regular Vehicle Transaction 4062391 - Valve Lifter Replacement - Both Sides 110,676 KM
06/03/2011 320373 ZREG----Regular Vehicle Transaction B7866 - Body Side Molding Replacement 60,175 KM
11/24/2009 34289 ZREG----Regular Vehicle Transaction B7288 - Headlamp/Composite Assembly - Right - Replace 31,612 KM
10/21/2009 33250 ZREG----Regular Vehicle Transaction B4660 - Rear Side Door Lock Replacement 28,163 KM
06/17/2009 142324 ZFAT----Field Action Recall V2077 - 08411 - Install Fuel System Control Module 28,161 KM
06/16/2009 210030 ZREG----Regular Vehicle Transaction X4421 - ODOMETER CONVERSION FROM US TO CANADIAN BY ESC 28,159 KM
02/12/2009 350971 ZREG----Regular Vehicle Transaction J5604 - Fuel Pump Flow Control Module Replacement 12,765 KM
11/04/2008 168673 ZREG----Regular Vehicle Transaction Z7200 - CORPORATE PARTS RETURN REIMBURSEMENT 3,173 KM
10/22/2008 163435 ZREG----Regular Vehicle Transaction N6608 - Emissions System Wiring and/or Connector Repair or Replacement 3,173 KM
07/29/2008 A03187 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
soulsea
Bar
Service departments and some other GM employees have access to the full warranty/service history of a vehicle, as long as it was performed at a GM dealership.It's not that difficult to get if you ask nicely cause there are always folks on GM forums that have access to the records, although it's usually better to ask before purchasing the vehicle rather than after. :)
soulsea
Bar
Note to self: Contact Drew next time I needs teh vine. :)
Where you at doubletap?
doubletapdrew
I'm in Oregon. We are still waiting for the 2014 sierras we have on order to show up, but I guess they revealed the 6.2L is going to be around 420hp so I have to wait to see the new Yukon Denalis :driver:
08grey
i know my tranny was replaced at about 20k but dont have any idea why, drew do you think they record that information?
doubletapdrew
If it was done at a GM dealer and under warranty they should. If you PM me your VIN i can look it up.
It probably won't say WHY though. Just that it was replaced.
Could be any number of things. In the 80's GM decided it was cheaper to replace whole components (engines, transmissions, etc) than the time and labor to tear them apart and fix what was wrong. The dealer sends back the core and GM rebuilds it and sells it as a reman.
soulsea
Bar
Usually the report reads worse than it really is, plus dealers sometimes will fiddle with the VIN ... I know my guys at the body shop will often grab another VIN when they do painting or demolding from me when they put it in the books so that it doesn't show up on my vehicle's VIN service history. Not often mind you, but it does happen. :emotions33:
It also happened when I traded my 11 Esky for the 12 and the dealer forgot to put in the new number ... found out a couple of days ago that all the LED headlamp swap work on the 12 has been going on the 11 VIN that I don't own any more. Which is fine by me but probably confusing to the new owner of the 11 if he/she ever sees the report.
The most infuriating thing to see in the report is the dreaded CCND ... then you don't know what the hell's going on.
soulsea
Bar
Customer Concern Not Duplicated
You take it in and tell them the issue, they can't replicate it when they go to work on the truck, so they hand you back the key without fixing anything.
dgrammer
I know this is an old post but could anyone possibly run vin 1gchk23182f192037 for service history? Buying this tomorrow and have the autocheck but it didn't really tell me anything and dealers were already closed today. Thank you in advance if so.
doubletapdrew
Here's what GM has:
Vehicle Information
VIN: 1GCHK23182F192037 Model: CK25743-2002 SILVERADO 2500HD 4WD CREW
Service Contract: No Branded Title: No Warranty Block: No PDI Status: No
Order Type: 70 - RETAIL - STOCK
Field Actions: 0 Open
Required Field Actions Open field actions are highlighted
Type Number Original Nbr Description Release Date Status
Customer Satisfaction Program N050546 05546 15,000 MILE - 24,000 KM FUEL FILTER CHANGE **IN EFFECT UNTIL SEPT. 30, 2006** 08/10/2005 Closed
Product Safety Recall N040007 04007 TAILGATE SUPPORT CABLE 09/17/2004 Closed
Branded Title
*The VIN information contained herein and information derived therefrom is the proprietary property of The Polk Company and is to be used only for the purpose of warranty verification and shall not be used for any other purpose whatsoever.
Vehicle has no current record of branded titles.
Warranty Block
Vehicle has no current record of warranty block.
Service Information
Vehicle has no current record of outstanding service information.
OnStar and XM Satellite Radio Information
Refer to Help page for details. For OnStar contact 888.ON.STAR1 (888.667.8271) and for XM Radio contact 877.GET.XMST (877.438.9677 Canada) and in the USA:800-556-3600.
OnStar Equipped: Y OnStar Status: Inactive
XM Equipped: N XM Radio ID: XM Status: NA
OnStar Vehicle Diagnostics: N DMN Enabled: N
Applicable Warranties Valid warranties are highlighted
Valid Description Start Date Effective Odometer End Date End Odometer
Emission Limited Warranty 03/22/2002 398 MI 03/22/2007 100,398 MI
Bumper to Bumper Limited Warranty 03/22/2002 398 MI 03/22/2005 36,398 MI
Special Coverage 04039 03/22/2002 398 MI 03/22/2009 200,398 MI
Diesel Engine Ltd Wty with Deductible 03/22/2002 398 MI 03/22/2007 100,398 MI
Corrosion Limited Warranty 03/22/2002 398 MI 03/22/2008 100,398 MI
Service Contract
Vehicle has no current record of service contracts.
06/25/2009 153423 ZREG----Regular Vehicle Transaction Z2175 - $15 Maintenance Card Promotion 161,016 MI
08/26/2005 329909 ZFAT----Field Action Recall V1242 - 04007 - Inspect and Replace Tailgate Support Cables inc. Hinge Replacement if Necessary 95,370 MI
08/26/2005 329909 ZFAT----Field Action Recall V1380 - 05546 - Replace Fuel Filter 95,370 MI
05/13/2003 098532 ZREG----Regular Vehicle Transaction D1002 - Blower Motor Resistor Replacement 35,063 MI
05/13/2003 098532 ZREG----Regular Vehicle Transaction Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 35,063 MI
05/08/2003 098415 ZREG----Regular Vehicle Transaction N6600 - Brake System/Traction Control Wiring and/or Connector Repair or Replacement 33,848 MI
02/22/2002 A92037 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
Looks like there were 2 field actions (recalls) but they've both been done.
davidl13
Hello,
I am about to purchase a 2012 yukon xl denali.
I would really appreciate any help i can get in finding out the service history on this vehicle.
It has 20k miles and has had 2 owners. Began life as a hertz fleet vehicle until 14k and then a private owner for 6 k.
Can you help me see the service info
Vin #. 1GKS2MEF1CR196459
David
CrackerJack135
