Airaid Jr installed. Question about resetting computer
Status
Not open for further replies.
JennaBear
Resident Ninja
San Diego, CA
Most people don't want to do the DIY mods, as most dealerships will come down ******* something like that.
I would be hard pressed to find someone wanting to hack up their intake box for testing on a new vehicle.
---------- Post added at 04:55 PM ---------- Previous post was at 04:54 PM ----------
NOT just between stock, stock with a aftermarket air filter and then with aftermarket air filter & intake.
We did do this a few years ago, I will have to find our results....
---------- Post added at 05:00 PM ---------- Previous post was at 04:55 PM ----------
Found the old link:
http://www.tahoeyukonforum.com/forum/showthread.php?t=809
And these are what were tested:
AEM no filter
KNN
AEM
Stock with KNN drop in filter
Outlaw
GMPP
Stock with Fram airhog
The dyno sheets in info are in Post #33.
D_R_C
I did the Airaid Jr. and also incorporated your airbox mod this weekend. I can feel a "seat of the pants" difference...
Todd
THANK YOU ! For sharing this info, there was at least one that disputed this mod.
If you would have done the Airaid Jr first then followed up with the mod after you drove it a little, you also would have noticed the difference between the two.
At least so far no one has stated a "seat of the pants" difference with only installing the Airaid Jr.
I'm glad this worked out for you, when you get around to doing EFI now they will be able to tune for the intake changes you have already made.
When you get the AutoCal you plug it in scroll down to "Read E38 and save then start over and "Read T43" and save then email these files to your tuner so he can write the tunes.
Its pretty simple, especially once you have done this.
I did my DIY mod first and had a few days of driving before I received my AutoCal to start the EFI tuning.
The power increase was pretty impressive with just the DIY mod, even better with the EFI.
When stock the Denali was pretty much a family joke with have not much power, it was pretty gutless.
It made a lot of impressive noise (exhaust sounds) but that was about it.
Now it makes noise and has the power to back it up.:waytogo:
---------- Post added at 02:16 PM ---------- Previous post was at 02:05 PM ----------
Found the old link:
AEM no filter
KNN
AEM
Outlaw
GMPP
Its NOT testing when you know something works from past experience's.
Beside the dealer can not see the DIY mod, but with the Airaid Jr they can see the intake change and if they want, they can and will make a big deal out of it.
The dealer won't/can't make a big deal on something they don't see.
JennaBear
Resident Ninja
San Diego, CA
Not sure what your argument is there. But at this point, we are beating a dead horse. I provided the dyno numbers as you have asked.
D_R_C
The dynos show the most improvement was gained from changing out the intake piping. That is where the restrictions are, so any upstream changes will have relatively minimal gains. In the end the gains are relatively low.
Don't get me wrong, I am all for DIY performance mods and have done quite a few on my vehicles. Since I am cheap and have little time to work on vehicles I have to be efficient in choosing my mods.
I applaud those who try various things and share :cheers:. If someone would like to dyno the larger intake hole, versus aftermarket, versus stock that would be great :peace:. IMO the results will be similar to the dynos already performed.
To point out something that most are not seeing or even thinking about, I do.
Check out the reduced section for the MAF sensor in the picture below.
Now if that MAF sensor section was a larger diameter coming out of the air box going into the larger diameter intake then you would have a wow difference in air flow.
But it is not larger its the smallest section in the intake system.
Your only going to move so much air flow thru the intake with the smaller section with the MAF sensor which does reduce the air flow.
The aftermarket intake helps, the DIY helps even more.
JennaBear
Resident Ninja
San Diego, CA
The AirAid is not smaller after the MAF, we have pictures of all the intakes we tested here:
http://tahoeyukonforum.com/forum/showthread.php?t=41254
The only thing that would be a problem would be if the MAF housing and the throttle body were two different sizes, which they aren't. The MAF housing on my 2010 is 87mm and my throttle body is 87mm, both stock.
Furthermore, if either were a major restriction, said restriction would be visible at high RPM only, where the engine would be incapable of pulling sufficient air through those items.
As it stands, the restriction for all components combined is a few percent in most cases (measured be engine vacuum) and the largest culprit there is the air filter.
D_R_C
Unless I missed it I did not see any dyno #'s with something like my DIY mod.
The problem I'm having is you jump on my DIY Thread saying by doing the DIY you won't gain anything or even get the numbers I'm getting, its impossible you say.
Someone has already reported back his findings which was positive.
So now who's beating the dead horse.
I did invite you'all the next time your in Phx look me up and I'll be more than happy to prove you very, very wrong. On a DYNO.
I realize your in the business to sell stuff, but I'm in the business to tell people good DIY stuff that works, sometimes just as good and will save people money. That's my goal in life.
:beer:
I'm pretty sure I stated the MAF is small going into a larger intake and from the picture its pretty obvious the Airaid JR is larger than the stock. BUT the air flow has already be restricted down to a smaller size with the MAF. If the MAF was a larger diameter that would help more.
JennaBear
Resident Ninja
San Diego, CA
I never said it was not a good mod, just saying that your numbers seemed very off. I also offered up empirical and factual data on how those numbers would be calculated. We have seen quite a few customers with the air box mod. I don't doubt that it is an ok mod, just saying that you had some lofty numbers.
He did report his findings, after installing BOTH an AirAid and the swiss cheese mod.
I actually am not in the business to sell stuff at all, I work for the Dept of Defense, not BBP as many would think. I offer up information in these forums purely to make sure that folks have enough knowledge of this stuff so that they can feel comfortable with their purchases.
Yes, BBP sells a ton of performance parts. But to be honest, I don't even have an intake on my Denali!
I have kept all my posts to you very concise and cordial. I am a scientist by trade and like true numbers and facts to base my decisions off of (not comparing apples to oranges or gas to diesel).
Seeing as how you are older than my parents, I would never disrespect you, but I respectfully disagree with you.
D_R_C
OK then we'll call it Agree to Disagree, and then drop it.
Zed 71
Pacific NW
Restriction is not only the diameter but also the frictional resistance due to bends, corrugated piping, and surface roughness.
Yes only so much air flow through the MAF is possible which is why any changes before the MAF will have minimal improvements as shown in the dyno testing results.
D_R_C
I don't know what type of dyno testing your doing, the dyno testing we have done says different.
The whole point of making more airflow available like what I do is the max available airflow is ready when needed. What your saying would be the same as building a ram airflow setup before the intake is a waist of time. You need to do more research and dyno testing the correct way.
Besides my vehicles in sig I did a ram air to my 79 K20 383 stroker, 95 Motor Home both netted hp increases on the dyno as well and by the dyno numbers increase of 15 HP on my 79, 17 HP increase on my MH, just with before intake mods.
Take away the airflow restriction = more available airflow = more power, period.
If people don't believe then that's your loss, no real professional would ever doubt this.
Maybe you missed this, page 2 #19
Todd
To this day I have NOT read anyone just doing the aftermarket intake claiming "seat of the pants" difference.
Zed 71
Pacific NW
Wow... Ram airflow is different than just providing a larger opening (before a restriction like the MAF which you agreed was limiting flow) or reducing frictional losses. Dynos were the ones referenced and I have not seen any data such as dynos that you have provided. Butt dynos do not count.
/thread
tights24
Where is this testing data? I'm all for doing something, but not without the data to look at. Not data on different vehicles either, but data on same models as mine. All vehicles react differently to mods, so i don't care what a 99 dodge did with a certain mod per se. Not arguing or trying to start anything here, just asking for the supporting data so I can figure out if I want to do this.
FWIW, I have the airaid Jr kit with their supplied filter and I "felt" a difference in the truck. Could be the sound making me "think" it felt better or peppier. Next time I'm at the track I can compare to my baseline numbers with zero mods to be sure though.
D_R_C
DUDE,
I was just offering something that DOES work quite well and the PERFORMANCE is quite noticeable. I know its not the same as ram but its darn close.
The dealership will see a aftermarket intake and will note this to GM, this mod is NOT seen unless the tech removes the air box. FAT CHANCE that would ever happen.
A few have said they did notice changes for the better, go back and read.
As far as dyno results when I can get my hands on them I will, since the shops have done these dynos and its been a few years for no charge they keep the results.
I was just trying to offer something that works quite well, apparently a few are not interested.
"ALOHA" I'm out of here with the stupidity from a few being discussed on this subject, its your loss.
I'm now off to Maui, Hawaii
tights24
Gotta love these forums especially the one's that have never done or tried anything but still put's their 2 cents in the discussion.
So, here's to hoping this wasn't directed towards me. Not sure why you're getting your panties in a bunch over this entire ordeal. I am merely asking for data and dyno results that you are stating you have for the Yukon. i would love to do the mod, but I don't want to spend my time doing it if it won't do anything for me. I also don't care about what the dealer sees when inspecting as a CAI does not void a warranty. It's called the Magnuson-Moss act. I've had my truck two months, so no, I don't have a lot of things done yet. Again, still wondering why the comment that seems to be directed at me..... I've modded lots of vehicles, and they all act differently to those mods. For example, apparently these trucks see nothing when it comes to an exhaust change. Just about every other truck manufacturer likes a catback replacement for power increase or at least a better flowing muffler. It looks like Chevy did a good job with flow on their stock setup.
regardless, I'm just looking for info. This isn't the only thread I've read of yours where some folks have questions or feedback or difference of opinion and you get all bent out of shape and frustrated and want to just walk away. This is about sharing info. I don't care how long you've been doing something or anyone else for that matter. if your own thoughts/trials are gospel or "end of story", then I will just not read them anymore.
Let's keep this discussion civil or the thread will be locked. Keep in mind everyone has their own opinion and is entitled to that.
tights24
Sorry about that 07Burb. Wasn't meaning to stir anything up, just looking for confirmation on the gains is all. Especially if there are Dyno results from the same truck on the same day. I don't want to spend time dremeling something for no reason.
D_R_C
No it was not directed to you, where I'm getting pissed is when another person on this forum that sells stuff claimed I could never get the numbers MAF g/s and IAT that I claimed, they was plain as day on the dyno and my AutoCal.
As far as dyno I've dealt with a speed & RV shop in Phoenix since 1970, he was my sponsor 1970 - 1984 NHRA.
The owner and I would get together every so often with redneck ideas, I do the mod he does the dyno, no charge. So he keeps the results, I'm in Maui now but when I get back I'll see if I can get the results.
This mod is not new it's been around the Dmax forums since 2007 and popular, yes I know Diesels are not the same as gassers. But the airbox pulls from the exact same location.
I'm tired of trying to offer something that does work and a few people that have no clue pic it to death.
Especially when a few have done the mod on this forum and stated it worked as claimed.
If people are afraid to try something that several has stated worked, at least 2 on this forum and 100's on the diesel forums, that's their loss.
Its really not that big of a deal to do, I don't understand what people are afraid of.
I understand the people that sells the over priced stuff, but I would have thought if someone wanted something that works just as good for less $$$, would jump on it.
There was NEVER any of this static on none of the Diesel forums.
Justin
Dan,
I think it is time to take a step back and re-evaluate your tone here. It is over two weeks since my wife's last comment here and your insistence to try and draw her back is a bit obnoxious. Since she is absolutely done with this discussion, but you insist to persist, I will chime in here. For the record, parts sales have zero bearing on our business. Profit margins in the autmotive aftermarket world are incredibly slim on such a low dollar item and in many cases we've made less than $5 per intake. But I digress...
Let's talk about the discussion that has been had. As far as I know, nowhere has it been said that your modification will be detrimental to the vehicle or power output. What has been in question are the claims and numbers backing them. Jenna is a scientist by day and evaluates the world from a scientific stand point. In that world, seat of the pants, "feels like", past experience, etc don't hold a candle to empirical data and testing/evaluation within the proper environment. I can't count the number of times that the "butt dyno" has reported gains or power losses that could be entirely explained by changes to density altitude.
Your claims were outlandish and unsubstantiated, regardless of accuracy. Period. Here is why:
First, idle airflow.
On a diesel, the engine is operated at wide open throttle at all times, there is no throttle blade. THUS, any change in airflow capabilities can be immediately seen, as any significant airflow restriction removal will yield more airflow at idle. Idle speed remains largely unchanged, as fuel quantity dictates engine power output and it is specified explicitly within the ECM.
On a gas engine, fuel delivery is a specific, fixed component relative to airflow. If airflow increases, fuel flow MUST increase and engine power output will increase (unless timing advance is significantly altered). With this specific fuel consumption scenario, a throttle blade is necessary to control engine power output and thus, idle. If you see an increase in airflow (g/sec), then your engine is consuming more fuel and unless the timing has been significantly retarded, your RPM MUST increase. Within the ECM, idle is controlled by declaration of a desired airflow (g/sec), desired idle speed (rpm) and desired ignition timing advance. The ECM will take those factors and based on feedback from various sensors, will adjust the final airflow via the throttle blade and ignition timing advance to achieve a steady idle at the desired idle speed. Unless there has been a significant drag placed on your vehicle concurrently with the airbox installation that would warrant an increase in airflow at idle (as you have claimed), there will be NO CHANGE.
Second, gains
Our dyno testing was performed following a very specific procedure to ensure impartial, objective results. In both cases, there were no pre-conceived notions and no expectation of results. That having been said, those results showed that the air box itself can be isolated as to having very little to no actual impact on power output gains. This can be extrapolated fom the fact that the factory air box (with OEM filter) with the airaid tube only performed just as well, if not better than each of the other kits utilizing both closed box and completely open element designs. Your claims that the hogged out box provides significantly more air flow just don't hold up, as it certainly provides less airflow capabilities than a completely open 4" K&N filter such as is found on the K&N FIPK and AEM Brute Force kits, regardless of fender hole size. And in a world where it does provide greater gains, those would only be at high RPM where the engine is not easily able to overcome the forces required to consume all air needed to avoid a vacuum in the intake manifold. On a GM 6.2L, this slight vacuum (indication of restriction) usually doesn't appear until around 4000rpm. By the shift point, it is usually equal to about 3-4% of engine power potential and represents the sum of all restrictions points including throttle body.
And lastly is the common sense test. IF reducing the amount of plastic used (read: cost savings) resulted in a very significant power gain and improved engine efficiency, wouldn't GM do it from the factory? What could possibly be their reason for not saving tens of thousands of dollars in material and increasing the vehicle's marketability? If that larger opening truly increased power to that level, I can see no drawback to it. The same argument applies to throttle body spacers, boutique spark plugs, fuel line magnets, etc.
Now, having said all of that and explained WHY your claims were challenged, I will bite. I will hack up the airbox on my completely unmodified 2013 Silverado 6.2L and will report results. I'll itemize and average out the airflow on the factory air box with the OEM tune installed and will hack up the box and do the same, repeating the test conditions as nearly identically as possible. Since throttle application can easily skew results, all testing must be and will be performed at full throttle to isolate that variable. Any "gains" at any other throttle levels do not matter in this case, since it can be the equivalent of just opening the throttle more or less. I'll be able to complete this after we return home from Maui.
I appreciate and respect your experience and history in motorsports. That said, the lack of reciprocal respect to any that question your claims is not appreciated. Especially when a thread such as this becomes completely de-railed from the original post which had nothing at all to do with air box modification.
Justin
Disclaimer to all others: I do not normally get into these kinds of topics here, but when my wife is persistently poked and prodded (on her birthday nonetheless), I'm going to take the matter up. I will be happy to elaborate on any points herein.
Status
JasonW4141
