Heater problems!!!
godoy
utah
So my heater is not working like usual air comes out not really warm almost cold but temperatures have dropped to -7 degrees f. Is that normal ??
Thanks
Sent from my TeleFonO!!
Wake
Stafford, VA
That's strange. The heater worked ok before?
I'm thinking you either have a plugged heater core or your temperature blend doors aren't working. I've had a stuck door before and on occasion had to cycle the temp hot to cold a dozen or so times to get it working again.
Have you disconnected the battery recently? I actually had a weird issue on my Escalade when I changed the battery this summer. Only got hot air for the first few trips in it after changing the battery. It corrected itself and hasn't had a problem since.
godoy
godoy
utah
Worked fine till temperature started dropping
Haven't disconnected battery or nothing
Heater core??
This is where truck temperature remains now use to be closer to the 210 mark
DWray20
Cochranville PA
It could be that your Thermostat is stuck open. It is Spring regulated to keep the temps at 210. If it is stuck open it cant regulate the heat right. Have you ever replaced it before? Just my thoughts.
godoy
godoy
utah
Never replaced before ill check it out
It's easy right?? Changed on other vehicles but not mine
Wake
Stafford, VA
I don't have experience on this truck but with a stuck thermostat on other vehicles for me the temp wouldn't get above 160F, it usually sat pegged at the bottom of the gauge in winter conditions.
I have seen odd temps though when I had a car with a coolant leak before and it was low on coolant. That also could give the symptoms of cool air out of the heater as well. Not enough coolant in the system usually means the heater core doesn't have coolant passing through it.
DWray20
Cochranville PA
I haven't done a thermostat on a 5.3 yet. but have done many others. they presented the same issues as you are having. not heating to the right temps. never had one act that way cause of a coolant leak though.
Rivieraracing
I agree with Wake's help he's offering up, if you coolant level is full then your thermostat is more than likely stuck open!! I had that happen to a pretty new thermostat on my denali some years ago, I had changed the coolant and replaced the thermostat when I did the water pump. 6 months later driving home at night in the winter from a boat show all of a sudden my heat turned to cold air. Looked down at the gauge and it was dropping to almost pegged out cold but then stopped right before full cold and stayed there all the way home!! NO HEAT AT ALL!! lol
Changed out the thermostat the next day and all was good again even to this day, I did boil the old one and low and behold it would get to full open and just stay there!!
With your temperature gauge where it's at and you have very little to no heat, I'd say you need a new thermostat, and while you are at it I'd flush out the whole system out real good with water!!
---------- Post added at 12:10 PM ---------- Previous post was at 12:09 PM ----------
And changing one out on our trucks is very very easy and simple to do, great access compared to some other vehicles that I've done in the past!!
godoy
godoy
utah
Thanks everybody for the help!!
Ima go buy a thrmosttat.
Thermostat is located in the bottom radiator hose right??
I turned my truck off just for a little while like 20 mins turn back on and already was the lowest it can be on the temp. Gauge
DWray20
Cochranville PA
Upper Rad hose goes to the thermostat Housing pull the bolts, pop it loose and its under there. i recommend draining your rad fluid first. so you dont make a mess. :happy107:
godoy
godoy
utah
Awesome would get it done tomorrow its really cold right now cold!!!!!
Thanks everybody for your help!!
godoy
godoy
utah
Ok have to get started on changing thermostat but weather ain't helping
Rivieraracing
Cmon man, from the looks of your sig picture the weather looks pretty good.......so get at it!!hahaha
godoy
godoy
utah
Hahahha
Well I did my feet were frozen tho changed the thermostat and temperature is closer to 210 now !!
Yeah it hit 45 here in PA today
Wish it were 45 here
---------- Post added at 04:43 PM ---------- Previous post was at 04:42 PM ----------
Thanks everybody for your help I really do appreciate it!!!:thumbup:
Rivieraracing
Nice man, was there anything obviously wrong with the old one? I bet if you boiled it with a thermometer in the water, you could watch it open up and get stuck open!! I've done that to a few because I've only had one obvious one and the rest I had to boil to see what it was doing!!
godoy
godoy
utah
Awesome! Glad it worked for ya. Glad we could help. Six about your feet lol.
---------- Post added at 08:20 PM ---------- Previous post was at 08:16 PM ----------
Sux* Damn auto correct lol
lol
I'll have to try that
but the gasket on the old one was torn
After replacing I could immediately tell the difference on the heating
briannorris
