My New Look: A complete exterior makeover
SC88
SC88
Chicago Burbs
So to update this thread! I ordered the kit from Norcal in July and finally got around to installing it last weekend. This truck kicked my ass during the process it took me 10hrs, new Ball joints, wheel bearings & alot of trimming of the plastic in the rear but it's finally complete!
It's the belltech 2/4 from Norcal with the belltech shocks and rear air bags
Ride height
Before
LF - 36.85
RF - 36.75
LR - 38.0
RR - 38.0
After
LF - 35.0
RF - 35.0
LR - 35.50
RR- 35.50
I will say It looks good, it's growing on me although a few of my friends are giving me a hard time about it being lowered saying instead of driving a SUV/Truck I now am driving a "fancy station wagon" lol I took all the measurements on the alignment rack and controlled / changed them as I felt necessary. The actual after results were lower but the ride quality was not what I wanted it to be for a DD, the rear bags were aired up and the front keys raised to get the ride height level and off the bump stops in the rear. The ride quality is pretty good but at times the rear seems a little bouncy but I haven't driven it alot probably 50 miles since lowering it so we will see if it improves as things go on.
My plan is to remove the roof rack but I cannot seem to pull the trigger on the running boards I think they look just right and go with the dark ass windows on the side but thats just me!
CHOO CHOO
BackPagePhil
Manheim, Pa
That looks great! Definitely a better look for ya. How do ya like the ride w/ the drop so far?
Sent from my DROID4 using Tapatalk 2
SC88
SC88
Chicago Burbs
The ride is something to get use to. I'm sure the 26s don't help it much anymore but you can tell it's lowered and at times the rear seems bouncy like I have bad shocks in the rear but that could be because of the air in the bags. on a scale of 1-10 I give the ride quality a 7! I was hoping it rode more like a tbss.
Looks muchhhh better. New sig pic time!
Thanks! lol yes.... I have some work to do.
CHOO CHOO
BackPagePhil
Manheim, Pa
Thanks!
did you put the new shorter bumpstops in? you could try the free travel mod as well. guess it depends if you have weight back there or passengers alot.
SC88
SC88
Chicago Burbs
New bumpstops are in they came supplied with the kit. When I first finished the install I didn't put air in the bags and it completely sat on the bumpstops and rode like shit! I put the air in the bags to keep the ride height controlled and off the bumpstops which could be the reason why it feels bouncy. I am not sure of the pressure but I am going to guess it's in the 10-15lb range.
Red_Raider
Derby, Kansas
Looks great man! I love the look of a burb dropped. Have you done any towing yet with the kit? I am looking at dropping mine but I wasn't sure how it would work with my camper.
SC88
SC88
Chicago Burbs
No towing, Probably wont until the spring time but I suspect with the rear helper bags I can just turn up the air pressure and keep the ride height the same. I usually tow my camaro so I figure around 5500-6000lbs total between car and trailer.
j_jerry79
