all on dome light mod
mazdawg(Mikey)
HGIC(head ginger in charge)
Lancaster SC
i installed led bulbs in my dome lights but i wanted to be greedy and have them all come on when the doors opened so heres what we come up with. pretty much its the same procedure as doing a 4hi or 6hi headlight setup. on the backside of the dome light assembly i jumped from the 12v side of the center bulb over to the 12v side of the side bulbs with diodes in line so no back feeding. the bulb mounts have spots where you can force a screw into it to make contact. the side bulbs still function like normal when the individual buttons are pressed but when the doors are opened, all 3 bulbs come on. i did this to both dome lights and i love it! heres the only pic i have. cant really post a pic of the light on because its so dang bright it screws with the camera.
PlazaEJ
Subscribed. Definitely want to do this one.
Thanks,
Mikey.
mazdawg(Mikey)
mazdawg(Mikey)
Lancaster SC
this is the actual dome light above the 2nd row seat and also the cargo area. i also found out that the round map lights and the very outside bulbs on the dome lights are actually 5v signals. thats why guys have had issues when they install led bulbs and they arent bright. my solution was to pull the overhead in front of the sunroof and tap the orange wire with another wire and run it down to beside the dash and catch 12v there. it made all the lights super bright and fixed it all.
heres a pic of the domelights im talking about. hard to see but all three are on in each light. when the door is closed you can still turn on each individual light on by their little button because of the mod
and heres some pics of the interior lights at night. these pics dont do it justice. my tahoe is an 06 so i added the floor sockets under the dash. next up on the to-do list is add the door lights to the back doors
PlazaEJ
5v, really? Unless there's something built into the 'Courtesy Lamp Relay', I don't see anything in the schematic to indicate a step down in voltage.
Very curious.
Tahoewhat
Ballin' on a Budget
TX
honestly i dont have a clue. they were just some laying around at work.
ok, pmed you also about another question
Very curious.
Yea, there is a thread about it from while back ago. 05-06, have something weird and the lights come on really dim w/ leds, but soon as you open the vanity the lights get bright.. / end thread jack.
mazdawg(Mikey)
mazdawg(Mikey)
Lancaster SC
Very curious.
yeah with the meter they only read 5v at both the sides of the dome light and also the round map lights. that was tested on my 06 tahoe, and 06 yukon, and an 06 escalade at work. the wiring for all of them origionate at a plug inside of the front console above the mirror. when i shot 12v with my logicprobe they lit up like a christmas tree. running a fused 12v wire to that plug ups them and helps with the dimming
PlazaEJ
Admittedly, I was reading the schematic for '02. I guess they're not as much alike, as we'd like them to be.
I do like your idea of more lights on, when opening the doors, though. I'm gonne check it out, on mine.
EJ
mazdawg(Mikey)
mazdawg(Mikey)
Lancaster SC
EJ
im gonna make mike a "kit" to do his. if things check out and you want some more info or maybe a "kit" just let me know. if your dome light in your 02 looks like mine then itll work out flawlessly
OmarR
Indianapolis, IN
I also do not have an older (02 or earlier) NBS to tinker with, but there is an old thread with this same mod. I just dont remember if it was this board or the older board.
JKMotorsport posted up his 02 pic, and I posted my 03:
Tahoewhat
Ballin' on a Budget
TX
Dont ever remember seeing that before. Could of missed it though. Glad Mikey brought it back up.
mazdawg(Mikey)
mazdawg(Mikey)
Lancaster SC
we almost soldered the connections on my domelight when i make a joke about using a ring terminal and screws to my coworker who already had the soldering iron plugged in.
MeanGreen03
TX
Are these the 3 amp 50 volt resistor diodes that are used in the 4-6 high mod?
Brace
