08 Z71 with 295/65/18 Goodyear Duratracs
Skywarp
Well, couldn't fit the Duratracs on mine with the CCM 2.5/1". Not sure why, but I would have had to do some major trimming to allow for wheel travel. It wasn't just rubbing behind the small black piece on the bottom of the bumper, it was rubbing a good 3" above that. Any travel up and down would have made it worse. Not sure if there is a difference between the 08 & 09 that made the difference. I did notice the small black piece on mine looks different than your 08's.
Ended up putting on a set of 285 BFG's. Will post some pics later.
Could it be because, he has a Z71, which has different shocking and different wheel flares? Just throwing it out there.
emann_01
emann_01
mine also rubbed about 2-3 inches above the black piece (removed) on the inner fender...one zip tie took care of that
progress
Yea, but this was moving the entire front bumper cover also because it was hitting it while turning. Wasn't just the wheel well that was an issue. As much as I offroad, was a concern that when that shock traveled it would have caused some damage.
laveycrafter
Emann,
Your rig looks sweet! I am looking at leveling my Yuk XL, pretty much same set up. I have one worry though......do you know the overall height? I am hoping it will still fit in my garage when I am done.
I'm thinking I may have to take off the roof racks. If you know the measurement it would be very helpful.
emann_01
emann_01
Emann,
thanks for the compliments!
i can get some measurements but i can tell you now that mine fits in the garage. I had to move the rear bar all the way back and the front rack all the way forward. This way the rear bar passes under the lowest point of the garage door before the tire rides up the garage floor concrete lip...this is when the trucks "lifts" highest. The front bar was moved forward for the same reason.
Does this make sense? if not, I can try to explain/take pictures to clarify
cjweb11
Houston TX
Emann,
First of all Gig ‘Em!
Second, that is a one bad mofo hoe.
I have a similar black ’07 Z71 stock, prepping for the truxxx 2.5” adjustable front leveling kit and likely the 1.5” rear spacer, as you have done. Once that’s installed, I’m debating which tires to buy: the BFG All Terrain 285/65R18 or the Goodyear DuraTrac 295/65R18.
I like the slightly larger size and slightly more aggressive look of the GY, but am more familiar and comfortable with the BFGs. (Also I have read some very mixed reviews of the GY DuraTrac tires)
So, since some time/miles have passed, are you still satisfied with the DuraTrac ride comfort, hwy handling, tread wear, sidewall stiffness/flex, etc? (assuming you are still running around on ‘em)
Thanks!
cjweb11
Houston TX
Anyone else who cares to share their opinion/experience, please feel free!
emann_01
emann_01
cjweb,
Gig 'em! Class of '07 here!
I absolutely love the GY Duratracs. At first, they seemed a bit "squishy" (sp) when changing lanes on the highway but then I found out that they were only inflated to 35 psi. I bumped them up to 50 psi and that is what I run in them constantly.
So tread wear...this is the great thing! They are E rated tires...as in heavy load, 3/4 or 1 ton hauling trailers load rating. The tread depth is almost as it was brand new to this day.
I do highly recommend the GY duratracs although they are a bit pricey.
Thanks for the compliments all!
Let me know if you have any more questions regarding my setup.
cjweb11
Houston TX
Thanks Creeto, and thanks emann for the info!
When i purchased the truck I was very content leaving everything stock (bought used: KMC wheels came on it) ...TYF has got me considering/purchasing parts/upgrades almost daily!
KCCO
cjweb11
Houston TX
Couple more beginner questions guys.
This is the $68 rear 1.5" level I'm looking at on ebay, I like that it has the rear shock extenders with it.
http://www.ebay.com/itm/BB-REAR-1-5-COIL-SPACER-LEVELING-LIFT-KIT-W-SHOCK-EXTENSION-4X2-4X4-/180940083890?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AChevrolet|Model%3ATahoe&hash=item2a20de92b2&vxp=mtr
1. Does this kit fit the Z71 rear suspension? (only specifies LS, LT, LTZ)
2. Does it become necessary/advisable to install longer sway bar linkages with a level to maintain handling? (front and/or rear)
3. Will the truck likely feel sluggish at 3.73 axle ratio with the larger 33" tires?
Thanks again
08z71tahoe
Houston
just spend the $369 for the rough country 3.5" lift... it has everything u will need, the extra lift will make a noticeable difference, and rides just like stock...
i have 305 55 20's and they don't really effect the performance, but rub a tad at full lock...
progress
Thanks again
I personally wouldn't buy a $68 leveling kit off ebay, but that's just me.
I'm running a CCM kit on mine with 285 BFG's and have had no issues at all. My tread is still strong. I need to put a new set of shocks on mine and am considering removing the CCM and putting the Bilstein 5100's that have leveling capabilities on there. I would take a look at those as well if I was you, they are getting outstanding reviews.
Gig 'Em as well, '98 here.
Zed 71
Pacific NW
FYI on another forum, some one put on the Bilstein 5100s and it wasn't as high as the CCM. Also there was less damping than the Z71 struts, so it was less firm/more roll.
progress
Good to know. Thanks.
felixgun
Lafayette, LA
I currently have a TGC 2.5" leveling kit up front and a 1.5" rear billet spacer in the rear. If I get bilstein 5100's all the way around, how much extra "lift" would I get?
Zed 71
Pacific NW
That would create a severe angle for the CVs and would not be recommended. I am assuming you meant leaving the 2.5" spacer and adding the 5100s to provide more lift. Also the rear shocks would not provide any lift in the back and you would have the Cali lean.
08z71tahoe
Houston
I had to do all the same trimming up front, Chevy likes to make it a pain in the ass to fit bigger tires... ur's looks great buddy.
really sucks that we all have this rubbing issue on our sway bars... anybody know a way to fix this issue with out a wheel spacer? i cant think of a way cause its probably impossible...
felixgun
Lafayette, LA
Aw ok thanks. Yes sir you assumed correctly. I wanted another inch or two but they don't make suspension lifts that small and they don't make an avalanche specific body lift. Thanks for answering!
Hodmjstone
