When I saw ur pics it didn't look like u had moved your sway bar over to clear bracket, and most people don't grind at the bracket like me to get it clearing. Glad u got it dialed in bro.
godoy- panhard bar isn't really designed to make the ride any better per say... It's mainly to reposition the axle back to center of vehicle. It did make my rear suspension feel alittle better, cause my lower trailing arms were binding up from being at an angle, which was my main reason for getting it and adjustable LCA. So guess u could say it did make the ride smoother, but only by putting the rear end in correct position as stock, i.e. springs, shocks, upper & lower trailing arms, drive shaft, all in straight alignment with each other, frame, axle and such and were they should be coming from factory. So guess u can say it made the ride feel better, but mainly put axle and wheels in center n even. Just my opinion from having with n without em.
Yuko04-not trying to thread jack bro, just givin some info, u shuld give urs
