Can you help me with OBDII code: P0430 ?
chip
Cincinnati
I pulled a "P0430 Catalyst efficiency low Bank 2" from the truck again today.
I've already replaced the plugs and wires. I've conditioned the fuel as well (Lucas upper cylander lube - Seafoamed a while back too). The only other things it shuold be, are Catalytic converter, or a valve guide seal.
Has anybody beaten this code before? Can anyone help me understand the issue better?
Thanks in advance!
Eschrichtius
Just found out I have this code today also...
Is it definitely the passenger side Cat? Or could it be something else making it throw this code?
Freedom Motorsports
Yes, it is the cat on the passenger side. After plugs wires and all, clean the MAF and throttle body as well. But I would take it to a exhaust shop and have them flow test the cats.
InTruckDesign
SW CT,
was just going to say..the downstream o2 sensor is bad. All that o2 sensor does is measure the cats efficiency and flow, the o2 before the cat is used for tuning.
animalfries
Is there any way to test the 02 sensor and see if it's bad rather than test the cat and if it's good assume the cat is bad?
Eschrichtius
I have the 6.0 motor and when I went under the truck I only saw the exhaust manifolds and one cat on each side after the manifolds, but Ive seen some people on other threads saying they had four cats? Am I missing something here? I passed SMOG last year when I bought it so I couldnt be missing any cats...
Freedom Motorsports
You only have two cats, one for each side of the engine. There is really no need for four.
chip
chip
Cincinnati
Yes, you can test any/all sensors with the appropriate sensor tester. I just bought a universal 4-wire O2 sensor for $20. That was my test. It worked, so I left it. Problem solved at the cheapest possible price, in the shortest amount of time (To be fair, I also bought and used a bottle of Cataclean....just to be safe).
You only need one cat for each exhaust manifold.
animalfries
Yes, you can test any/all sensors with the appropriate sensor tester. I just bought a universal 4-wire O2 sensor for $20. That was my test. It worked, so I left it....
I have a scan tool that tells me volts for each sensor. Any idea what should they be reading?
Eschrichtius
I replaced my passenger side Cat on Tuesday and reset the code. My truck only has a total of 2 cats, passenger and drivers side after the exhaust manifold. And a total of 4 O2 sensors, before the cat and after the cat.
Seems to have fixed the problem so far, no more codes as of yet. I will update if the code comes back...
chip
chip
Cincinnati
My NBS Denali had 4 cats... I am 99.999% certain
Are you sure it didn't have 2 cats and 2 resonators?
Not sure, but I just found this on Google: http://troubleshootmyvehicle.com/gm_oxygen_sensor_4.3L_5.0L_5.7L/oxygen_sensor_diagnostic_1.php
I'm sure there's plenty of info out there.
I really hate to say it, but if I had to bet a dollar, I'd bet that your code will come back in a week or two (if you didn't replace the downstream o2 sensor as well). Cats rarely go bad, especially in well maintained vehicles.
Eschrichtius
Ive had catalytic converters go bad in 2 cars that Ive had before, it just comes with age like replacing a muffler. My technician said that if it was the O2 sensor, that it would've thrown a separate code for that.
chip
chip
Cincinnati
My Dad was a mechanic all my life (before he died). He taught me that you always replace the cheapest suspect first (in these situations). I'd be weary of any shop that starts with the most expensive thing first. Did they offer to refund your money if they end up being wrong about the cat?........because you can replace the o2 sensor yourself, for $20. How much did the cat cost after parts and labor? I'm just sayin'.
BTW: What code did you have?
This helped me understand things a little better. Maybe it can help someone else too: http://en.wikipedia.org/wiki/Catalytic_converter
Eschrichtius
P0430 Catalyst system below threshold bank 2
Yeah I hear what your saying, they always stand behind their work, and if there was any issue I know they will take care of me like they always do.
chip
chip
Cincinnati
Then that's all that matters. I just wanted to prepare you for the possibility of that code coming back.
Let's hope I'm wrong. ;)
worleytrev93
