Muffler Help needed
95escahoe
Hello, I have a 1999 GMC Yukon and I recentely purchased a flowmaster 40 series muffler off of amazon. BOTH amazon and the flowmaster website said this muffler would fit my yukon and I am wondering if this is true, if not what should I do?
http://www.amazon.com/Flowmaster-43...GMC|48&Year=1999|1999&vehicleType=6&carId=001
should fit I run a 3in inlet and outlet muffler on my 95 Tahoe and fits fine, that is the correct size Flowmaster stated for my year use a different brand muffler tho
TigerEyz3
Slow and Steady
TN
http://www.amazon.com/Flowmaster-43043-40-Muffler-Aggressive/dp/B000QJG1AS/ref=au_pf_pfg_s?ie=UTF8&Model=Yukon|558&n=15684181&s=automotive&Make=GMC|48&Year=1999|1999&vehicleType=6&carId=001
Typically, a single-inlet/single-outlet (SI/SO) muffler will NOT fit a stock 1999 Tahoe/Yukon unless the stock system is modified with a Y-pipe. In stock form, most 1999s came with a 2" dual-inlet/2.75" single-outlet (DI/SO) arrangement. It's common to install 2.25" or 2.5" dual piping instead of the restrictive factory setup.
If you've already ordered the SI/SO muffler, you have a few options:
  1. return it
  2. y-pipe your system to accept it - most any muffler shop can handle this task
  3. sell it and purchase a DI/SO muffler of your choice that is designed for your application
Clarification: some Tahoes/Yukons did come with the SI/SO arrangement, most 1999 4dr models had the DI/SO configuration though. For future reference, it's best to look under your rig to see what you need before ordering.
Here's a LINK to the cat-back that I have on my rig... DI/SO (centered outlet)
Ahenley18
Ahenley18
New Braunfels TX
thanks for the help, I think ill go along the y-pipe path, that way I dont have to reship the muffler back to amazon. I could just buy a y-pipe online right? I would think it would be cheaper.
steamroller
The South
Unless you're collecting exhaust parts for another vehicle all together, a 99 is still an OBS so those headers linked won't fit.
992dr
Eastern N.C.
It would be easier to get the right muffler. Couldnt you get a call tag from Amazon for free return shipping?
ez,
Those headers and Y-pipe are pretty nice but, they're for a NBS Silverados with a 5.3.
TigerEyz3
Slow and Steady
TN
Not the Tahoe/Yukon, unless an engine swap was done... The LS motor (4.8/5.3) wasn't used in the Tahoe/Yukon/Sub until the 2000 model year (not counting the 2000 Limited Tahoe/Yukons which still had the 5.7L).
The 1999 model year for the trucks used the 4.8/5.3/6.0 motor... the headers were likely used on that rather than the Tahoe/Yukon/Sub.
19Yukon97
The only Flowmasters that fit on the 96-99 Yuks,tahoes, and burbs is the 70 series big block mufflers. Everything else has to be modified. I run Pacesetter longtube headers with armor coat, 3 inch piping with new magnaflow cats, and a single in single out 50 series delta flow, with 3 inch piping out the stock location with a 3 inch to 4.5 inch tip.
---------- Post added at 03:13 PM ---------- Previous post was at 03:08 PM ----------
I forgot to add this...
oh you can get an excellently made magnaflow y-pipe for 25$ off of amazon. Just measure your inlet pipes and get the right one. I still run the stock setup with the piping and everything. I mean with the dual in/single out setup. Just running a dual 3 inch in/3 inch out y-pipe.
Heres the link for the y-pipe...
http://www.amazon.com/Magnaflow-107..._1?s=automotive&ie=UTF8&qid=1327691540&sr=1-1
DefendHawaii
Snake Eater
Kahala HI/ Seattle WA
I can't confirm this but I will say about the 2 in to 1 y pipe that you attach before the muffler it is a bad idea. It will congest the flow of the exhaust to the muffler. This is what I had planned on doin before I did dual in single out magnaflow. My buddy runs the shop I went to and he said that it would actually be counter productive in getting better HP and MPGs. Either run duals or get a single out with a dual in.
992dr
Eastern N.C.
I've read that thread on LS1, good info. Those Burns pipes are amazing.
DefendHawaii
Snake Eater
I am just saying doesnt it seem like it would restrict flow?
At the end of the day dual straight pipes or flows is still better then any Xpipe or y pipe set up you can build.
992dr
Eastern N.C.
Seriously?
Using the proper size tubing will not restrict anything.
A well thought out exhaust system will have either an H, X or Y pipe.
JeffK
