A/C compressor dead?
MMitchum
I've got an '06 Yukon Denali. When I manually turn on the A/C I get no cold air or dehumidification (is that a word?!) I get no tell-tale click or momentary RPM reduction when I turn it on, either. Just nothin.
I have checked all fuses and everything looks in order. I'm thinking the compressor or maybe a relay? (Really hoping it's a relay!)
Any thoughts or ideas would be greatly appreciated.
-Mitch
ATL
turn the ac on, and look at the compressor to see if the clucthes are engaged. these compressors go out alot. my compressor started goin bad, and when the clutches would disengage, it would snap the belts, which usually ended up cutting the trans cooler lines
TnTahoe
TN
Mine has broken belts and the tensioner and I still cant figure it out lol
M
MMitchum
Ok, not sure how to check the compressor clutches but did find something (very) basic that was wrong... AC belt off the pulleys and split down middle. Replacing both belts (serpentine too) now as they have some shine and minor cracking.
Feeling pretty dumb/blind right now.
But now I'm concerned that it wasn't just a worn belt that caused the problem... though, I did check and compressor turns.
ATL
thats what they do as the compressor starts to fail. when the clutches disengage, it doesnt just spin to rest. the compressor wont free spin like that, when it disengages, the belt goes from whatever rpm your belts are running at to 0 INSTANTLY! its violent enough to snap belts
start the truck, and have someone turn the ac on and off as you watch the compressor. you can see it engage and disengage
Drewphil
