auto ride pump...
mhorn0817
maryland
have a 04 denali, yesturday the SRC message came on the dash, turned truck off and started back up a few times and noticed the compressor never kicked on, same thing today, compressor never kicked on. can i just assume the compressor is dead or is there anything else i can check? i did notice before the pump stopped that it seemed like it was running more then normal, so maybe a possible leak as well? any ideas...
uvacarbuff
Mine did the same a couple months ago after towing a friend's boat. Apparently the exhaust release valve broke and caused the compressor to overheat and fail.
I ended up disconnecting the ride control and air ride and going with Bilsteins.
Front: BE5-6500-H0
Rear: BE5-E380-H0
Parts and labor cost me $450.
It rides great and I love the stance:
M
mhorn0817
maryland
yeah i thought about doing that. but the ride control is a nice feature...especially when carrying people or towing...i cant stand the rear drag look when got some weight back there...
PUGLIA
Oklahoma
Many things can cause the auto leveling to fail. Ditch the system and replace with Monroe load assist shocks in the rear( lifetime warranty) and replace the springs with Z71 springs if there not already in there. You can always use a load assist bag if you need the extra leveling. Throw some bilstiens up front and your good.
Hendo
ive gone through 2 compressors and am in the process of lifting my escalade and dumping the auto ride all together.. ive never been a fan of how the truck looks sitting parked and then leveling out when its riding.
M
mhorn0817
maryland
so within the past 3 months, every once in a great while the pump will kick on softly and i wont get a src message...but like i said every once in a great while, maybe once a month.
what do you guys make of this? i plan on keeping the autoride
Rivieraracing
You say softly, was it loud up till it stopped working and now when it does come on it's alot quieter? If so, I'd say its done, just surprised it's still working at all!
M
mhorn0817
maryland
that is correct...before it stoped working it was loud and it seemed like it it was kicking on more then normal...but now that it has stopped working and it kicks on every once in a while it is way more quieter.
Rivieraracing
I'd say it's shot, but that's just a guess!! Have you tried hooking up a heavy trailer to see if the back end sits on the bump stops and if the pump even kicks on when it should?
When my pump died on me, you couldn't tell that the shocks were empty of air by looking at how it sat, you could kinda tell by driving it and there was no doubt when I hooked up my travel trailer and literally watched the truck sit on the bump stops!!
M
mhorn0817
maryland
no i havnt hooked anything up to it...most weight ive had in the truck was 6 people total...330 up front...430 in middle...300 in rear seat and that was about a month ago...not sure how it sat but it rode fine and the pump never came on
briannorris
