Does it fit in Garage?
twistedwhisky
Southern California
Does it fit in Garage? Yep, Pix
This might be a silly question but you fellas with NNBS z71s with ccm 2.5 front 1.0 rear and 285/65/18 tires, do they still fit in a standard 7ft garage door? The wife says i can do whatever i want to her wagon as long as she doesn't have to park outside! I appreciate any help you can offer.
soulsea
Bar
A standard NNBS Hoe is 77 inches or 6.42 feet, leaving you approx. 7 inches to play with (gigitty) ... not sure how much taller the Z71 is + the kit you want to install, but you might have to KY the ceiling.
How attached are you to the roof rack?
Oh and welcome to TYF! :)
Cartwright
I would think you should be able to fit. Some garage doors are shorter then others though.
twistedwhisky
twistedwhisky
Southern California
Thanks for the welcome Soulsea! I think if i had to remove anything just removing the crossrails would give another inch or so. I've got the credit card out ready to order the CCM 2.5"/1" leveling kit and BFG T/A KOs. I would just hate to find out after its done (and bada$$ looking) that it doesn't fit. The overall diameter of the stock tire (Duellers) is 31.5 and the BFG is 32.8. So I figure with the 1" spacer and new tires it shouldn't be more than 2" taller in the rear. I measured it stock and have about 6" of clearance. If i'm an idiot please advise. Thanks!
soulsea
Bar
Dustin, as you will inevitably discover as you make your way through this community, my validation is considered the ultimate empty gesture and should never result in any form of reassurance, nor is it a foundation on which to make a sound decision. That is to say that I am the least qualified person to gage others' idiocy level given that mine is off the charts. :)
It sounds to me like your calculations are correct, but there are many more folks who are truly qualified to tell you for sure ... including some with the setup you're looking to go with who could probably go and measure an exact height for you.
But I'll be here for the moral support and stuff. :)
emann_01
i have 2.5 front and 1.5 rear leveling kit with 295/65/18 duratracs and mine barely squeezes under the door. I had to reposition my roof rack to get it to slide in without bumping the door.
(my garage door is a old and hangs a little bit and I have a small lip of concrete right at my garage entrance)
Night Fury
Southern California
my neighboor has NBS z71 with front leveling kit (i beleive durastar) with A/T's dont remember which ones and it fits barely with no rubbing on roof rack.
jdpber
GOLD MEMBER
The America
Im running 6"s and 35s NBS and my roof racks bump the garage door and the antenna.. well it smacks the shit out of the door.. i barley skinny in. all i can say is do like i did,. screw it ill find out once it is lifted.. but i feel you will be fine....
Zed 71
Pacific NW
I have pretty much the same setup and it fits but just barely (I also have the roof rack cross rails on). Others have fit NNBS Tahoes with 4-inch lift and larger tires, but I honestly do not know how they get it in a standard garage opening.
twistedwhisky
twistedwhisky
Southern California
I truly appreciate all the response guys. I feel pretty comfortable with going ahead and ordering the goods. Thank you and i'll post pics when i get her done!
twistedwhisky
twistedwhisky
Southern California
Done! And it Fits!
domin8
Just Plinking
Highland Park, IL. Transplant from SLC, UT to redu
Ya'll are a lucky bunch of sob's. Mine's too big to fit in my wife's tiny garage. 07 LT1 4x4 with Ready Lift 2.25/1.5 on stock 20" wheels and tires (still) and factory roof rack. I managed to barely fit in a 6'10" parking garage, so I know the clearance to my garage that was built in 2007 is smaller.
Sent from my myTouch_4G_Slide using Tapatalk
brice715
