Demolding
ghostworks
Norway
I've see that a lot of you guys have removed all emblems and side moldings, I was just wondering how you guys have done it? And how the paint looks underneath.
Don't want to rip my moldings off just to find out I need to repaint all doors :)
I got some tips about using a hot air gun, and label off - anyone got a better method?
Huck
Whut Thee Huck?!
San Diego
fishing line and goo gone works. the paints fine under the emblems and trim.
I use a plastic spackling tool. Make sure it's new or in very good shape as not to scratch the paint. Then a 3M adhesive eraser wheel will take the adhesive off effortlessly. After that just a good polish of the area and you're good.
NoPh33rRaCiNg
Kent, WA
This ^ the 3M wheel takes 5-10 mins, so much faster and easier than other methods.
gdddup
NJ
x2 this thing works.
when i pulled my rear molding n emblems i used fising line, plastic sraper, goo gone, and wd40... it was a pain. when i pulled off the roof mouldings. i used the 3m wheel and my cordless drill. works awesome. and no sore fingers.
h4mmy
slc
I'm going to have to use the 3M adhesion remover wheel for the last bit of adhesive where my decals were. My index fingers were rubbed raw after doing it manually.
And this is why you ALWAYS just use the wheel from the beginning :deal:
polobuds
East Bay, CA
Step 1: heat gun
Step 2: fishing line
Step 3: 3M wheel
Don't waste your time with anything else. You'll be done in 1 hour
alacran
be care full not to burn thru the clear so dont leave it on to long.
G
ghostworks
Norway
Just want to thank for the tip to get the 3M wheel, it did the work in no time!
ThwopKing
Bunker Hill, WV
Ill be doing this in the next few weeks and plan on doing it the right way first with the 3m wheel.
G
ghostworks
Norway
I highly recommend the 3M wheel, I spent about 15 minutes pr side doing it, once you get the feel for how much pressure to put on the wheel you'll be surprised how effective it is.
jem556
KY
Is the 3M wheel used dry...or with some type of compound?
SuburbanPassion95
