sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
i meant can you do a full Front shot with just parking lights on. I wanna see both on at the same time
Two issues ...
1. I am awaiting your 'I told you so' ... the beam is crap, weak, and all over the place even with hids in the halos. No dangerously so, but close. This will accelerate the oem retrofit project.
2. I don't know if the installers messed something up or if they changed a setting cause my inside courtesy lights aren't coming on. I was sure the setting for that was in the dic but I can't seem to locate it. All I can find is an exit light timer setting which I assume is for setting how long one wants to have their headlights on after they exit the vehicle.
Basically wwhen I turn off the engine the inside lights are supposed to come on automatically, same when I unlock the car with the fob before I start the truck.
Help!?!![]()
Did you put HID in the projectors or use the stock H1 halogen bulb? Not sure how those lights work. My guess is the Halos are not designed for actual driving light only for looks.
argh.. I cant decide what to retro fit. These lights or the Oem. Suggestions anyone?
nah no offense. Its one of those i need to see in person type of deals. My new idea is oem housing, Tint the entire housing black cause with projectors, no need for the reflector housing anymore.
Just a fyi, not sure if you know this or not, but the oem housings must be cut open since the typical oven bake method won't loosen the adhesive enough to remove the clear lense.
Go with the OEM retro.. Sorry just those lights look soo much like a Ricer.. don't mean to offend anyone about that..
