HID Installation, someone please help...
R_Sharpe
VIP
Tennessee
Alright, so today, I finally received my DDM Tuning HID Kit. Now, I have no clue how to install it. Heres a picture of everything that I received, what goes where? Please help, I would like to get them in soon, and it's almost dark outside.
Untitled by Robby_Sharpe, on Flickr
I got a wiring harness, two ballasts, and two 8000k bulbs.
If someone could just tell me for sure if I have to use the wiring harness thing, I would be fine.
nj462
NJ
unplug the headlamps and plug that wire into the ballast, then use the new wiring harness to connect the ballast to the new bulb
tool2269
SA, TX
fyi same kit and I am NOT using a wiring harness on my 09 tahoe. no issues to report. its still sitting in the box
Terrence87
easy install
---------- Post added at 12:12 AM ---------- Previous post was at 12:11 AM ----------
just plug n play
R_Sharpe
R_Sharpe
VIP
Tennessee
Alright, sorry for such a delayed response... So Myke, since you said that you didn't use the wiring harness, I'm thinking that I'm just going to try to plug them in tomorrow. Thanks.
tool2269
SA, TX
I believe you'd only need the harness attached if you notice the HID-lights flickering or slightly dulling for a second when you do certain things, like roll up the windows.
heres what DDMtuning says
Use this relay harness to connect HIDs to cars with very small gauge wiring that cannot supply the initial surge current required to light the bulbs reliably. Symptoms indicating the harness is required would be intermittent starting or lights going out after being turned on for several minutes and requiring you to turn the lights off and back on for them to turn back on again.
R_Sharpe
R_Sharpe
VIP
Tennessee
Alright, I installed them yesterday. They work, so... I haven't noticed any flickering, or anything wrong for that matter, so I guess that you really don't HAVE to install the harness. Thanks for the help. :).
CKendrick
