Very Hard 1-2 shift, Service Stabilitrak Light
Brougham
Estevan Saskatchewan
My 07 Yukon recently developed an interesting issue, it will randomly flash up a "Service Stabilitrak" "Traction Control off" or "Service Stabilitrak" warning message. While this warning is displayed and only while its displayed, it will shift very hard from 1st to 2nd gear, the shift is hard enough that if I'm accelerating hard while doing this, it actually chirps the tires. (I've now been avoiding hard acceleration).
I'm trying to figure out if this is an issue within the TC/Stabilitrak system causing the transmission to shift hard, or a transmission issue causing the warning messages to come up.
Has anyone run into this before?
I had a local transmission shop that I've used for years, look at it quickly and they're stumped, no errors from the control modules other then that the Stabilitrak was disabled.
I'm going to start by checking all my wheel sensor wiring this weekend, if I don't find something obvious I guess I will have take it back into the shop for them to tear into.
Any suggestions as to what would cause this? Perhaps problem areas I should look into?
(I've searched the forum and could not come up with anything specific, just different trans problems causing a similar error message on an older model)
Metro
Los Angeles/NYC
I had the same issue happen to my 2007 Yukon Denali. It also wouldn't allow me shift into reverse. I had it towed to the dealer and they saw the error codes (Stabiltrak Off, Service Stabilitrak, Traction Control Off, Service Traction Control) but it went away as quickly as it happened. It has happened a few times since and If I drive it for about 20 minutes and the let it sit for 20 min, it goes away.
Zed 71
Pacific NW
Similar issues. Took it to the dealer and it was a bad front wheel bearing sensor. The entire hub had to be replaced thankfully under the 5yr/100000 mile powertrain warranty.
B
Brougham
Interesting, mine will come and go while I'm driving, mostly disappears while on the highway. I haven't had any problems with reverse though.
---------- Post added at 09:06 AM ---------- Previous post was at 08:47 AM ----------
I'm hoping its something similar, was your entire bearing gone or just the sensor? I know they don't sell them seperatly, but it'd help me track down the issue, I'm still hoping it just a broken wire from the sensor, those bearing hub assemblies are pricey.
B
Brougham
Possible resolution to this problem, recharged the battery!
When this problem started I'd been practically living in my Yukon for a week on a jobsite, running power inverters to charge laptops, a cel booster going constantly, recharging phones etc. etc.
I just attributed the issues I was having to extremely rough roads, copius amounts of mud and water that I had to drive through to work everyday (yes, I actually use and abuse this thing on a daily basis).
I didn't always have the truck running and a couple of times completely drained the battery, had to get boosted to restart it. I think because of this my battery wasn't holding charge properly anymore, so, I put it on the charger over night. I've put about 50miles on it so far today with no issues, the problem would usually show up after 2-3 miles.
I've got a couple hundred more to go, so, we'll see what happens.
To those of you more technically minded, does this make any sense as a cause/solution??
Would inadequate voltage to the TC system cause this?
Zed 71
Pacific NW
It doesn't make sense because once the engine is started, the alternator should be providing power. If it works, great.
To answer your previous question, the front hub and wheel bearing sensor were both replaced even though they determined it was just the sensor. You would think that if they could have only replaced the sensor (under warranty) then that's all they would have done.
Sneffels
My 07 Yukon recently developed an interesting issue, it will randomly flash up a "Service Stabilitrak" "Traction Control off" or "Service Stabilitrak" warning message. While this warning is displayed and only while its displayed, it will shift very hard from 1st to 2nd gear, the shift is hard enough that if I'm accelerating hard while doing this, it actually chirps the tires. QUOTE]
For the last 2 or 3 years I have had this same problem with my 07 Tahoe. I'ts been to the dealer twice and they cannot tell me what's wrong.
Is there any new information on this problem?
GM Customer Service
Michigan
Sneffels,
I am sorry to hear that you are experiencing issues with your Tahoe. Have you spoken with Chevrolet Customer Assistance about this yet?
Thank you!
Elizabeth, GM Customer Service
Sneffels
Elizabeth,
Per your suggestion, I contacted GM Customer Assistance.
They told me that there are no service bulletins regarding this issue and that I should try to take it to the dealer immediately when the problem occurs. Right... If the problem wasn't so intermittent I would have done that by now.
The best news that came out of the conversation was that my extented warranty doesn't expire until 2012. So I guess, I'll just keep driving and hope that something "breaks" before the warranty expires. Or maybe I can try to get the dealership to look for the wheel bearing sensor problems mentioned in an earlier post.
GM Customer Service
Michigan
Elizabeth,
Sneffels,
Please let me know if the issue does happen again. If it does, I encourage you to get it into the dealership as soon as possible. Is there a specific time when you experience this issue?
Thank you!
doubletapdrew
Mine did that a few times. If it happens and you are near a dealer don't shut it off, they need to hook up the Tech II while it's still throwing the codes. Turning off stabilitrak/TC is a "failsafe" mode that could be caused by any number of issues. Mine was a module on it's way out in the tranny, fixed under powertrain warranty.
TylernKY
same Problem, need help with a true solution. the wheel sensors are not the culprit
Started yesterday afternoon on my way to an emergency farm visit (I use the Suburban for my VET practice.).Lights indicating Stabilitrak and traction controls are now off. Then they go out, then back on four times will driving down highway at approx: 55 MPH. Then it stated to service, which would go on and off. Then finally all off and everything was fine by the time I made it to the farm.
2 hours later, with a very ill animal in back that needed emergency surgery, the same happened again on way to office an hour away. Will lights were blinking on and off , the truck became sluggish and then the steering locked up and then released , after that I tried to pull over and the brakes failed for about 15 seconds, then started working and the truck stalled and would not restart. Thanks to several people, they helped me push the truck off road. Meanwhile having an assistant rush to come and get me and the dying animal. After thirty minutes of trying to keep the animal alive: I tried to restart the truck and it would turn over and would continue trying to crank itself for a solid minute with out me turning the key. after three attempts, it started and no lights and ran great: But, with all the loss time, by the time I made it to the clinic and prepped for surgery the animal died. That 45 minutes of truck trouble has caused me to lose a clients animal , that I could have saved.
This morning, the truck started with no problem. Then at clinic, I go out to start and it did the continual starting sound for about 45 seconds and then it started, but, when drove down the road, between first and second gear a loud boom and jerk and the gauges went haywire and the stereo went to full blast and the brakes quit. This is obvious a very dangerous occurrence that could be deadly.
After searching all the forums etc, this same exact problem is happening to many 07 and 08 tahoes, yukons, denalis, suburbans,silverados, cadialliac xts and envoys, But, to no avail: the solutions that seem to be a multitude of try and see attempts with great costs to the owner that does not seem to work. I do not want to go thru weeks and weeks of attempts of replacing this and that in which does not fix the problem. Also, it is troubling that with hundreds affected, Gm nor the dealers have a solution. This to me is a potential life threatening defect if steering or brakes fail to work properly, especially if it happens at higher speeds as it did with me.
Is the Body Modular sensor truly the culprit? Has anyone really gotten the problem fixed? I want to be able to take it in, but, want to have the solution or the recommendation for the repair center to follow. After talking to three service center associates at three different dealers, all three said they have heard of the problem many times, but have no idea how to fix it...Really!? If lives are lost due to the dangers this proposes, I am afraid it will resemble the Toyota Brake fiasco.
How many vehicles does it take with the same exact problem and dangers before a recall is suggested?
Thank you all and I love Chevrolet, but, this needs to be addressed.
If anyone has had a successful repair, please let me know what you had done. thanks all!!
GM Customer Service
Michigan
TylernKY,
I am very sorry to hear about your experience. I am glad that you're safe. I would like to investigate this for you. Could you please send me your full contact information? I will need to know your VIN, full name, address, phone number and mileage on your vehicle. Please send this information to [email protected]. When you send this e-mail, please put ATTN Elizabeth or Liz.
Thank you!
dlktahoe
I had the same problem with my 2009 Chevy Tahoe, getting the messages "Service Stabilitrack, Traction Control Off, etc." Happened on numerous occasions...could usually drive at a speed of 30mph tops...at one point did lose everything...luckily was already headed toward pulling off side of road. 1st dealership "serviced" my vehicle, stating the issue was the throttle body. And that is was regular maintenance and I was charged...didn't fix the problem. When it reoccurred...2nd dealership, towed & replaced throttle body at no cost under power train warranty...that problem has yet to reoccur? Does seem like when you look at these forums, we are not the only ones...
GM Truck Man
2007 Yukon SMAE PROBLEM
I think my 2007 Yukon XL has now beat the record for any car I have owned for the amount of problems and service we have had to perform: an oil consumption issue that according to GM is normal (1.5 quarts every 3k miles), bad wheels sensors, remote start problem, alternator, a window switch and finally- an issue that began about a year ago that seems to be occurring more frequently lately.
The transmission shift lever on the column will sometimes lock, not allowing to move from PARK, as if I don't have my foot on the brake petal, despite having my foot on it. Then, after lifting my foot off the petal and back down again it, and wiggling the lever a bit, it will allow me to shift. Simultaneously the "service stabilitrac" and "service traction control" warning lights appear until I turn the car off again and it sits for 5 minutes. The first time it happened it went many months without issue, then it happened 3-4 more times about 3 months ago. Until recently I had just assumed it was due to me shifting the vehicle into drive too quickly after starting the vehicle. Within the past two weeks however it has happened 10-12 times, including three times today. I am now concerned since each time this happens the lever remains locked and we cannot put the car into drive.
GM Customer Service
Michigan
dlktahoe,
I am glad to hear that you got your vehicle fixed. If the throttle body falters again, please let me know.
Thank you
---------- Post added at 11:17 AM ---------- Previous post was at 11:12 AM ----------
GM Truck Man,
I am sorry to hear that you are experiencing these issues. Did your dealership give you a diagnosis for your Service Stabilitrac and Service Traction Control light issues?
Thank you
dlktahoe
Elizabeth,
My 2009 is now out of warranty. We have been GM loyal as my husband and his father were employed by GM for many years. This vehicle is the nicest, most expensive purchase we have yet to make...and I am beginning to question it. We had to pay for the service on the throttle body, the back chevy badge is falling off, and after a hard rain on friday, the door apparently filled with water due to a questionable weld/seal. I do love the vehicle but the problems are adding up. You spend the money on an american made SUV because that is what you want...but when it starts having problem after problem...you question whether or not the money spent was smart.
GM Customer Service
Michigan
dlktahoe,
I do now that the doors do have a drain hole that any water should be coming out of. It could just be plugged up. However, I would like to look into this for you. Could you please send me your full contact information including your VIN and current mileage?
Thank you
Sneffels
Elizabeth,
Wish it were that easy. This problem is totally intermittent. For example, yesterday I drove 50 miles round trip to the airport with no event. The day before, on a short trip of about 6 miles, I got the gong and "stabilitrak off" and "service stabilitrak" messages 3 times. It goes sometimes weeks without incident. It's totally random.
One thing I have noticed - it always happens when the vehicle is coasting or slowing down. It never happens during acceleration.
GM Customer Service
Michigan
Sneffels,
I completely understand and I do apologize that you are experiencing this issue. The only other thing I could suggest right now is that you have someone from the service department at your local dealership take a ride with you and see if the issue arises. You could coast or slow down while driving to see if it shows up.
Thank you
HeavyHoe03
