which exhaust to get?
trublew
im looking at getting a new bolt on catback, i guess it would be called... i really only want a little bit louder than stock, so im not sure what to get... i want a bolt on option, and want a pass side exit... what do you guys suggest?
Mbrp has a nice set up. Look in stylintrucks.com...
Another option would be just replacing your existing muffler. Cheaper and approximately the same results :shrug:
T
trublew
Yea I don't want loud as its the wifes dd... Just a little more rumble... So magnaflow is the best road?
I just got the Magnaflow 12589 and it's about perfect. A few others on here did the same and seem to like it. Flowmaster 50 Series will also give you a nice rumble without being too loud...
A 40 series flowmaster as suggested earlier will be too loud for a wife's DD IMO...
blueflamed03
Oklahoma
no need for catback like Jacob mentioned...just get a 50 series Flowmaster. Slight rumble, nothing bad, and inexpensive.
T
trublew
i havent looked at the muffler recently, is it possible to unbolt the stock one and bolt up a new one? or do i cut off the old one and weld in the new one?
Cut out old muffler, then weld up the new one
T
trublew
id rather have a bolt on system so if and when i get tired of it i can just pull in the driveway and swap over, no welder needed... i think im going with the magnaflow if its relatively quiet...
Max
Mile High
Denver
Just have a muffler shop weld up a flowmaster 50 or a magnaflow. You're dropping a good $400-$500 on a catback that doesn't net much more gain than a simple muffler swap. They sound awesome dumped over the axle facing down too...then there is no need to maintain the finish on a tip :cheers:
x2....You can get the 50 series or Magnaflow for around $100 and a shop shouldn't charge ya more than $40 to just weld it up there. You could do this swap several times before you spend the $400 - $500 it'd take for a cat back system :deal:
andrewmoore13
i love my 40 series with dual exit
i have an 02 denali though, so a little different
skyl3rm
Ahoy hoy
On my 01 hoe I have the 50 series. Love it. Sounds good... not too loud but still a light rumble.
T
trublew
i think ill end up with magnaflow...just needed to hear what you guys typically run... thanks for everyones input/suggestions
any sound clips/ pics would be awesome btw
Go over to my exhaust thread to hear mine. I just posted it over there...
2005yukonxl
ours was dumped just after the muffler and it drove me nuts with the drone..no way around it since its bouncing off the pavement and the bottom of the car...i had to get it exited out properly in order to maintain our sanity...plus its safer when she's sittin in traffic, no exhaust going under the car w/no place to go...
vsaravia
