hesitation/stumble 95 tahoe
ERIC95TAHOE
Southern Wisconsin
i have a 95 Tahoe with the 350. when its cold if you tap the gas it will kind of stumble or hesitate a bit. while its warming up it will sometimes randomly hesitate when you go to take off. i wouldn't really say its a miss though. then when it warms up fully it will have a little shake to it. i just changed the plugs and wires on it about 4 months ago. any ideas whats going on here?
raptorforme93
Tampa, Fl
Mine used to hesitate when I first started it but after I changed the wires, plugs, and dizzy it was all cleared up. It used to have a noticable shake to it at idle also but that it mostly cleaned up. Is it normal for these trucks to have a little shake to them at idle?
ERIC95TAHOE
ERIC95TAHOE
Southern Wisconsin
i did notice it seems to shake at idle only when its warm outside. my hesitation/ stumble is mainly if a snap the throttle kind of quickly. when its cold and sometimes when its warm. what are my injectors suppose to look like when they are spraying? i looked down in there with a timing light and they seem to throw fuel all over the walls both exactly the same though.
robbie
mine was doing something similar and i put it on computer and it says it is the crankshaft positioning sensor
ERIC95TAHOE
ERIC95TAHOE
Southern Wisconsin
its a bit annoying but not $235 annoying lol. im going to put a new cap, rotor and coil in. it seems to be worse when its wet out its raining right now and i noticed it every single time i took off
retorq
Kingman AZ
Get yourself a computer and cable and hook it up to see exactly what it's doing. If it's not throwing a code it's something mechanical like a bad plug, bad wire, loose wire, cracked boot, base timing is off, etc.
ERIC95TAHOE
ERIC95TAHOE
Southern Wisconsin
new plugs new wires did it before i changed them. i just set my timing back to 0 it was just a hair bit advanced about .7 degrees. its OBDI so not much i can really see with it hooked up to anything Im going to put a new cap/rotor and coil in soon im sure that wouldnt hurt. there was a bit of corrosion on the coil where the wire connects i cleaned it off when i changed the plugs though.
clean454
Dis-connect the vac line from the egr valve and we if that helps if it does then the egr valve is bad mine was doing the same thing and that was the prob.
retorq
Kingman AZ
I know it's ODB1, so is mine. I got myself a cable and hooked up my eeePC, it makes tracking stuff like this down soooo much easier.
ERIC95TAHOE
ERIC95TAHOE
Southern Wisconsin
i was doubting this till i tried it haha i pulled it and didnt hesitate or stumble anymore.
busafreak
Try taking it out and cleaning it and the ports first before replacing it. I have a stumble on mine too that im trying to track down also on my 95. Gonna try this today. I also purchased the aldl cable to see whats going on in there..
ERIC95TAHOE
ERIC95TAHOE
Southern Wisconsin
think it might have been chance that it quit hesitating when i unplugged that yesterday. i pulled the egr valve off cleaned it (it wasn't too dirty anyways) and hooked it up to a hand vacuum pump and it worked properly.
ERIC95TAHOE
ERIC95TAHOE
Southern Wisconsin
back to this again, never got anything to hook it up. i just bought some regular tune up stuff for the heck of it like cap, rotor, coil pack and ignition control module. i did not replace the pickup coil though. it needed it it had plenty of GFS on the coil. anywho that made no difference. so i started to play the hit and miss game, put a new egr valve on it (due to the fact i cleaned it and the next day it went out lol) and i put a new IAC and i put a new temperature sending unit on. about a year ago i changed the fuel filter and put new screens on the injectors (it still stumbled after that too a year ago) the stumble almost seems kind of random now. seems to be fine if you slowly push the throttle down but if you do it any quicker than slowly it will hesitate a bit and stumble. a few weeks ago i noticed a new issue, after its been ran for a while and i have the ac on and shut it off for a few minutes and go to start it it will start up and die, but if i turn the ac off it will start up just fine. it also has a little bit of a rough idle. any ideas this time? if not i guess im going back to the hit and miss game until all sensors are replaced (wouldnt hurt either since im assuming there is 192k on all the sensors)
---------- Post added at 07:47 AM ---------- Previous post was at 07:40 AM ----------
guess i should have added i changed the plugs and wires in febuary some time. and timing is dead set at 0* and i replaced the tps about a month ago due to a shifting issue a long with the neutral safety switch do to it not showing the right gear (i guess all that really effects is that and the tcc and the ability to start in park so who cares about that i just sayin thats what ive done ha)
Bob LaFord
