285/70/17's on 03 yukon
red yukon
huron, SD
i've got an 03 yukon slt. i'm planning on getting dick cepek torque wheels (17x8.5) for it and 285/70/17 fierce attitude MT tires for it. i already cranked the torsion bars on it. i know i might have to trim a little bit but i want to make sure this setup will fit. ps i am new to this site.
AquinoSteven
Key and Spacer Guru
Clinton, NJ
Since your still running stock keys you may have to trim quite a bit but if you go with some aftermarket keys youll be set.
swtz71
Mass
you will rub.. you will need to crank sock keys to start, see how it goes but lift keys and rear spacers would be better..
R
red yukon
huron, SD
thanx for the info i knew the backspacing of the wheel was going to be the biggest problem it doesnt bother me to trim a lot
swtz71
Mass
just be careful not to trim to much on the drivers side front inner fender well, the washer reservoir is there..
fermonarez
