95 4x4 Tahoe sreeching from engine compartment.
jzaldivar
Lemoore CA
New belt, new idle pulley, new tensioner, new water pump, new alternator, cleaned pullies and still screeches when i rev up, at idle it doesnt. Im stumped, I need help. Im low on cash and don't want to spend anymore. Ac compressor is a possibility but i power it on and no change in noise as if if it was the problem. I bought a month ago and didnt do this until a few days ago but did it before i bought all the parts above, except for the belt. Please help guys.
Juan
retorq
Kingman AZ
Drop some water on the belt and see if the noise goes away ... might help you troubleshoot it.
99Yuk
Northern Ontario, Canada
Please don't laugh. My neighbor is an old cat. When my wife's Jimmy was screeching like that at revs but not at idle, he took a bar of soap and held it to the belt while it was running at idle. The belt obviously ate away at the bar of soap leaving white streaks all over it. After 1/4 of the bar of soap was gone he stopped. Then he had me rev the engine. The noise was gone. Stayed away for about a week until the soap wore off. He said it needed a new belt. I replaced the belt and that solved the problem.
I know you mentioned a new belt already, but try the soap trick and see if the noise stops. If it does, then the belt may be defective and need to be replaced.
Disclaimer: I know nothing about mechanics, this is just was my neighbor did for me. Stop laughing!
retorq
Kingman AZ
It's not funny!! The soap acts as a lube, the water will do the same thing till it dries up. If the noise goes away with either the soap or the water he has a belt issue. Too tight maybe?? Could be slipping on one of the pulleys ...
LOL
SunlitComet
OBS Jedi-Do Good
unknown at this time.
if it is **** it all the time then I would say something is wrong with that new belt(maybe to long causing the tensioner to become lax)or tensioner. If you let the tensioner snap back on it own it will almost immediately get damaged.
Verfy the application and exchanged them if needed for possible bad parts.
Maybe you cleaing solution for pulleys affected the rubber belt perhaps glazing it really bad.
blackcoffee
O.G. Black.
Tensioner & idle pulley but you already mentioned that. Hummm...
J
jzaldivar
Lemoore CA
Screeching
Its a new belt and did the soap thing and made no difference, it only quiets down when i spray it with conditioner on the groove side. Anyone have a pic of the proper position the of the tensioner on a 95? tensioner looks a little low to me but thats the proper belt for that application for an 105 amp alt any other belt is longer.
retorq
Kingman AZ
There is a sticker under the hood that should show the proper routing ... do you have AC??
tsarms
sounds like belt is loose, causing slipping, thats why you only hear it at higher rpms and not idle. even though its a new belt it could be bad or new tensioner could be bad as well.
J
jzaldivar
Lemoore CA
sceeching
I dont think it is the tensioner it was making that noise with the old tensioner. I notice the belt rides back and forward a bit but noise doesnt seem to be coming from there. I spray conditioner on the grooves and it quiets down. Im stomped guys.:emotions122::shocked:
retorq
Kingman AZ
Did you get a pic of the routing of the belts yet?? It's not as simple as you would think. It's possible to miss that pulley under the AC .... that might cause an issue or two.
J
jzaldivar
Lemoore CA
screeching
I didn't ask for the routing pic. I know its routed correctly I followed the diagram. I wanted pic of the tensionr position
99Yuk
Here's mine. It may or may not help you though. I have UD pulleys and a non-stock belt, but it should help give you a rough idea about where the tensioner should be.
99Yuk
Dope. Your right, sorry.
EDIT: I was searching google for a pic of the belt routing for you, and I found a pic of fellow members BigBlueBus rig. He was the #6 search result. Now thats funny right there!
retorq
Kingman AZ
DOH! Sorry I misunderstood. You want a pic of the tensioner position with a stock belt?? There are three lil triangle marks on mine, if I understand right the adjustable triangle has to fall within the limits of the other two. When you look at it form the top and see the marks I think you'll get what I mean. I'll be under my hood later and can snap a pic f you still need ...
---------- Post added at 09:30 AM ---------- Previous post was at 09:24 AM ----------
Edit: If you look at this pic on ebay you can see one of the triangle marks ...
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?VISuperSize&item=170552318701
TahoeJim
SE Ohio
Just had a new alternator installed on an F150, genuine Ford piece, etc. From never hearing 1 peep in the past 6 years, it would have a screech from hell as if a possum was under the hood and getting ground up at least once every time it was driven, even short trips of less than 15 miles.
Original belt, tensioners, pulley, everything....6 years old/83,*** miles. It was the new alternator actually. They had to replace it due to the voltage regular being out of wack and now, no noise.
the big blue bus
richmond, va
mine has been making a screming noise lately too. its rather anooying. im pretty sure its the ac and i might take it off and bypass it and get new bearings for it. does anyone know where to get the bypass pulley for a 95? i can find em for 96 and up but not mine
ZaZaZazzels
