Help - running rough, new plugs, wires, cap and rotor
99Yuk
Northern Ontario, Canada
Oooookay, so it looks like there were several codes here they are:
16229684
16213195
86BNHP947148AP8
GA225300
100913
I don't even see a P1345 in there...
:bawl:Am I ever gonna get my truck running right again?:bawl:
Honestly, those don't look any codes I've ever seen. Don't they almost always start with a P? Maybe ask him again. I'm not getting a good vibe from this guy.....I dunno.... Your asking the correct questions, and getting fluff anwers back.
gulleyman
gulleyman
TX.
So I picked up the used ECM at Pick & Pull today, was running short on time so I had someone pull it for me for $10 and bought the 90 day warranty for another $10, $50 total.
When I dropped it off with the mechanic we compared it to the original ECM and I realized that the numbers he gave me earlier were the numbers "off of the ECM" not the trouble codes!
So he's gonna try this ECM tomorrow morning, hopefully this will just fix the problem. If not I'll post up the error codes tomorrow :(
I emailed Justin w/ Black Bear to see if he could set me up with a performance tuned ECM, how much it would cost and if there could be any issues with doing this considering my dilemma. Haven't heard back from him yet. Crap I want my truck back!
On a positive note, I got my HID's in today :D
gulleyman
gulleyman
TX.
:( ECM didn't fix it :(
The mechanic said that when he pulled either the crank or the cam sensor out it looked like the oil may have been a little milky. He recommended that I take it to a dealership for diagnostics.
Here's the scanner codes:
P0300
P1345 A
What do you guys think?
99Yuk
If you've changed all the sensors, checked compression and vacum, and it all looks good, then has any one said anything about bent valves, valve guides, or valve seals yet?
I'm asking because valve guides turned out to be my problem on my original motor. I too had two cyls misfire randomly. but I had other symptoms like the plugs would foul every week, and I'd go through a litre of oil a week, etc.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
As mine has at least one plug fouled where oil is on the outside of the block deck where I ironically have two adjecent cylinders with compression at 145 at each while all the others are 170 and their injectors or off spec in regards to flow purge test, the left head is going to come off and be checked my a machine shop. I would like to do it myself and document everything for others but the fact that I live an an apartment with no garage it would be hard to manage this mess and I cannot control the enviorment or space around the truck keeps turning me off. I also don't have the money to see it thru quickly as opposes to maybe a few months S i will probly save enough and let a shop do it all at once.
---------- Post added at 08:12 PM ---------- Previous post was at 07:53 PM ----------
P0300
P1345 A
Same codes again!
Gulley, I had a thought. If your mech can't get the right scanner to read that cam retard, put a fine clear alignment mark on the distributor to block or across the dist. cap that is aligned with some component on the manifold easier and try this:
The p1345 code responds to any alignment being off more than two degrees of correlation so while running bump your distributor about a degree ata a time either way. If it gets engine acts worse or, stalls then you restart and problem is still bad, you are heading the wrong direction.
Do go more than 4 degrees to start either way. Clamp down then clear codes. Make driving trips similar to what you were doing before. Try this route a few times I would imagine if the code p1345 stops showing up you are withing the threshhold, the distibutor would be back to normal and maybe the misfire will go a way. I f I had a scanner right now with that code it a no cost way to try and you really can't cause damage.
I am sure you know what I'm trying to explain.
99Yuk
If there is milk in the oil, there are other problems. Can you confirm that? By pulling the dipstick and taking a look?
And if he's recommending that you go to another place, that's his way of nicely telling you that he's stumped and doesn't want to work on it anymore. The easy stuff to diagnose he did already. Go somewhere else. And at some point it's a case of diminishing returns for him. The extra labour to diagnose this further he will never recoup from you the paying customer, so he's telling you nicely to move on.
I do understand and feel your pain and anxiety. I just went through this a year or so ago. I ended up soul searching my budget options, and picked up a new GM crate motor from a dealership to drop in. Of coarse I didn't know that a 383 existed until two months after it was installed I joined this forum and discovered that it was only another $1000 to get the 383 instead of the stock 350. Dope!
At some point you will have to decide to take it another shop (possibly dealership and continue to dump money into this motor), or buy a new motor.
The milk in the oil, may be the tipping point towards a new motor. At least it would be for me.
Other option would be a rebuilt motor, but I just read a couple of days ago about a fella on here who 'saved' some money and bought a junk yard motor vs crate motor, only to discover it was f*cked, and now he has to buy another. That guy didn't save any money.
That's the biggest reason for the new crate motor. I didn't want to take my chances. I was so strung out after failure after failure on my existing motor, I wanted peice of mind knowing that when I turn the key on my truck, it will start, each and every time. That was worth the extra $$$. And I liked the new three year warranty on the motor.
SunlitComet
OBS Jedi-Do Good
Sorry I didn't see the milky oil part.
I would go along with 99 at some point but is there a possiblity of you being in a cold climate with a lot of short drive trips that would cause the condensation inside the engine not to burn off lately?
Has your coolant, engine and tranny fluid been stable that would undicate a mix somewhere?
In reading over the instructions of a crank and cam sensor replacements I did not see any indication that oil was exposed so I would assume he was still looking at other causes or like 99 said he just might be giving up.
If you did find an oil fouled plug then by all means consider having the head taken off and inspected.
At some point a line will have to be drawn on costs of continue inspections or just start fresh with a another motor.
I will still say that if the dist. code still can't get removed then you will have to revisit the dist. and gear and wear in the valvetrain from the camshaft gear in the back being worn to worn timing chain assy. and anything in between on the bank with problems.
If all is fine with that then it should eliminate mechanical failure side of the p1345 code was describing putting you back at square one with a possible alignment problem which is correctable and prehaps check the inside of the dist. cap for eveidence of damage. That should be the only physical link between the two sensors. If you had a wire loose are break in either you would be popping a different code.
If your up for continued diagnosis I would go for getting a good scanner for yourself and subsribing to alldatadiy.com. I am going to look at contacting a company about the scanner I mentioned before to see how deep the ysytem goes and how much it will cost for myself and will write back with the info.
---------- Post added at 04:00 PM ---------- Previous post was at 03:15 PM ----------
Gully try these links. There are what I believe what one would need to really dive in the computer system. Each link represents a item that needs to be purchased to get to the detail enhanced parimeters results. The total would be about $320.
It is pc based so if you have a laptop that would be great. I have an unemployed one that I actually may put a permanent mount in my truck for.
hardware w/ free basic software: http://www.scantool.net/scan-tools/obdlink.html
Professional software: http://www.scantool.net/software/scanxl-pro.html
Gm enhanced sofware: http://www.scantool.net/software/scanxl-gm-enhanced-diagnostics-add-on.html
This last link of enhanced perimeters is to big to post so here:
http://www.palmerperformance.com/support/supported_vehicles/gm_enhanced.php
All that should give you alot as long as your vehicle support those perimeters.
I am still looking but this is going to be my first choice.
Have not found a phone number for them yet but I think it is all online support.
99Yuk
...Gully try these links...hardware w/ free basic software: http://www.scantool.net/scan-tools/obdlink.html
http://www.palmerperformance.com/support/supported_vehicles/gm_enhanced.php...
Hey, thanks for those links. That's some pretty neat stuff. It would be kinda neat to set that up on the 8.9" screen of a HP Slate tablet mounted in a center console. I know I'm dreaming, but it would be kinda neat.
gulleyman
gulleyman
TX.
I don't know enough about this stuff to do it myself :( dropped my baby off at the stealership this morning for diagnostics, wish me luck!
---------- Post added at 10:03 AM ---------- Previous post was at 09:29 AM ----------
Check this out sunlitcomet and 99Yuk:
http://store.mp3car.com/Car_Computer_Systems_s/25.htm
99Yuk
gulleyman
gulleyman
TX.
Okay, so I called the dealership yesterday to see if they had figured out what the problem was. The guy tells me it's the plugs and the cap...
I asked if he had read my email and shared it with the tech (I emailed him all of the things that have been done up to this point). He said that he had not read it. I told him I would send it again, he said he would call me tomorrow (today) if he did not see it.
I went back to the dealership today to check on their progress. He says he still has not read the email and that the tech has confirmed that the cap and the plugs were bad and that they had to start there.
He said that there were a couple of plug wires crossed and that Autolite plugs would not work in my truck, because the heat range was not right. Said that the cap was firing in two places at the same time because it shorted when the wires were crossed and it was firing back into the cap.
They wanted to charge me $80 for the diagnostic and another $440 to change the cap, rotor and plugs.
I asked if they even tested the cap and plugs to see if they were bad because they had just been replaced...twice. I asked if he even shared this information with the tech, he said he did and had to stick by his recommendation.
I told him I would pick the truck up and give him his $80 in half an hour...
I'm pretty pissed, I think the dealer is just throwing the same parts at it that I already have instead of really diagnosing the problem.
What do you guys think, are they yank'n my chain or should I get another cap, rotor and some GM plugs and try it again? Damn sure not gonna pay them $440 to do it and tell me that wasn't the problem :emotions122:
SunlitComet
OBS Jedi-Do Good
Based on dealership parts prices and labor rate to do it seems high but there labor rate might be higher than others. Ussually when repairs are done any diag. fees are put toward that final cost. I would have demanded that with a no charge if wrong clause if possible.
Crossfire damage can happen and those autolites are not a good idea either. I love the Honeywell Corp. but the fact is some vehicles are picky. I used a bosch cap on a nissan stanza with dual plugs per cylinder and nothing but major misfires when in overdrive. Went away with oem.
I would trust the dealers diagnosis. That is the immediate problem although there might be more. It seems like they want to take an unbias view and that is the way to start.They have more experience and training and see this stuff on these vehicle more than anyone else I am sure.
My opinion is get acdelco cap, rotor and the platinum plugs using part numbers specified by dealer where ever cheapest inspect your wires closely and electrically for any damage and try againand double check your firing order. Included here http://www.sunlitcomet.com/images/automotive/93025186.gif if you want a second reference although I think the cap is marked. Disconnect your battery the while doing the work to ensure code erasure if you don't have a scanner yet. Maybe even read you plugs and cap and post what you find.
If the problem is not solved and you have to go back, what you would have paid them to do it the first time would have paid for both first and second diag. visits and your parts. Still save money.
If it is solved you still saved.
I do not however know how the p1345 code is going to be affected. IMO it is that possible distributor alignment that is causing the problem but not the other way around unless the crossfiring in the cap is electrically interfering with the cam sensor. I could be wrong.
gulleyman
gulleyman
TX.
Well, I got the truck back and it's in the backyard again :(
Thanks for you help Sunlitcomet, hopefully it was a combination of the injection system taking a dump and the Autolite plugs :emotions122:
I'm gonna try swapping them again and hope the problem is gone. I talked to Autozone, they might give me a refund on the plugs, cap and rotor since I bought two sets and both went bad in under 100mi. Maybe I can recoup a little bit of my money.
If this doesn't work I guess I'll be talking to another mechanic or just replacing the engine, obviously I will exceed the cost of a reman'd engine at the dealership in no time at all :Wedgie:
gulleyman
gulleyman
TX.
So I replaced the cap, rotor and plugs for the third time, this time I used the ACDelco Iridium Plugs like the dealer suggested. All of the plugs I pulled from the truck looked terrible again. It still runs the same.
I got an email from Justin of Black Bear Tunning, I had emailed him a while back when I was going to replace the ECM to see if that was the problem, was going to replace it with a performance tuned ECM.
Justin asked if anyone had mentioned the o2 Sensors (the front ones) because it sounded like a fuel delivery problem. This is something that I haven't heard yet or thought of myself. The mechanic said that it was dumping a lot of fuel before and after the fuel injection system upgrade to MFI. Any thoughts on that guys?
SunlitComet
OBS Jedi-Do Good
Unless something was disabled in your pcm codes would have been thrown for a malfunctioning oxygen sensor, front or rear-side to side, or for something they see out of the ordinary such as left or right bank to rich or lean. How convinced are you about the quality of that performance tune? Have you gotten rid off the sensor code yet.
gulleyman
gulleyman
TX.
...How convinced are you about the quality of that performance tune? Have you gotten rid off the sensor code yet.
I don't actually have a performance tune yet, I just bought an ECM at a junkyard for $50 and swapped it out to see if the problem would go away but it didn't. Still getting the same codes as before.
Looking back it seems like this all started with the truck running real rich every once in a while, then gradually it started to miss a little and the check engine light started to come on intermittently, then a few months later it would just stay on, so I had O'Reily scan it for codes and they told me I'd need a tune up soon, then a few months after that the CEL started blinking and it was running really rough. That's when I replaced the cap, rotor, plugs and wires...now we've replaced those three times,
Pulled the distributor and checked it
Re-adjusted the timing
R&R Injector spider w/ new improved MFI
R&R crank and cam sensors
Checked all the wires to and from the ECM with an ohmmeter
R&R ECM
Checked compression,
Checked the sweep (for TPS failure)
I've thought about replacing the motor thinking the only thing left was a warped head but that wouldn't fix the issue with it running rich and fouling plugs would it? Seems like I'd just have a new motor with the same problem. The only things that haven't been replaced in the ignition system is the distributor and coil, I think?
Justin suggested o2 Sensors, what else could possibly be left? Seriously, I'm at a loss here:emotions122:
95TwinTT
Minnesota
Seems to me you are treating symptoms here. The same parts are replaced over and over with the same results.
There are other failures that can contribute to running too rich. The comment about being intermittent at first is an important clue.
I would be looking towards things like the MAF (Mass Air Flow) sensor and the MAP (Manifold Air Pressure) sensor. Even the IAT (Intake Air Temp) sensor. Seems like you go into a failure that causes all 8 plugs to come out black. Oxygen sensors are a possibility, but they would seem to want to fail one at a time rather than all four at once.
If you have a lot of miles, could be wiring degradation, possible broken wire. Know it’s a pain to do, but checking wiring between these above mentioned sensors and the ECM, while moving the wires as much as possible might be a cheap test.
And then there is the distant long shot of run-a-way, fuel pressure. The ECM has no way of knowing what the fuel pressure is.
So before you order up a replacement engine, might want to do a little testing on these sensors. :imo:
veteran111
