Vette servo???
BOSS
The People's A D M I N
Dallas
I just ordered the superior shift kit and super servo set, will update everyone...shop does alotta race engines so they won't work on it without hooking it up to the puter first and evaluating the trans while I drive around. They're telling me you may cause the tranny to wear out quicker by changing the servos out because there is a change in the dynamics of the tranny bc of the new servos?
BOSS
heftylefty58
CA
...they won't work on it without hooking it up to the puter first and evaluating the trans while I drive around....
BOSS
Dang.... Sounds expensive. How much did they quote you for the servo install?
Grocery Getter
A guy with a truck.
Phoenix, Az
So I got my servo yesterday and I have my case of RP. I called the transmission shop and they want $100 for the flush and $65 to do the servo.....WTF. I think I will do it myself, who has done it and how did it go?
tybardy
everyone needs a Hoe
Gilbert Arizona
you cant do the flush youself, that requires some vacuum equipment. However dropping the pan, changing the filter, and adding the RP should be good. (if you have a deep pan i think its like 5 quarts, 3.5 i think for a shallow pan... dont quote me on those though) Im pretty sure this job is a pain in the ass, if i recal, there are a few obstructions making the pan drop difficult
As for the servo, i have not done this yet as i am having some tranny issues i think, so i am holding off, however i have heard that it is a fairly easy and not to time consuming of a project.
heftylefty58
CA
Earlier this year, I tried to install my servo on my 2003 Yukon Denali b/c I couldn't get my @#%! heat shield off. So, I've had my servo sitting on my shelf since then. Coincidentally, this week, I called around local transmission shops to get quotes for the install. Here are my findings:
Shop1: $100 (but they barely spoke English, so I'm not sure they knew what the hell I was talking about)
Shop2: Refused to install customer-provided parts due to liability issues.
Shop3: (ie, Moore Buick Pontiac GMC Dealership): $428. No joke.
I guess my servo will be collecting dust for a bit longer.
danimalmax
louisiana
the corvette servo is actually pretty easy to install, it takes a while, but all you need are a few basic tools, i was scared to do mine at first but once i got started it wasnt so bad, i just did mine last week actually
heftylefty58
CA
Once you get to the servo, yes, I've heard that it's fairly easy to install. I'm guessing you're not aware of the heat shield setup on 2003 Yukon Denalis....
Grocery Getter
A guy with a truck.
Phoenix, Az
I'm, just gonna man up and do it this weekend, I just need to go grab a c-clamp. F#$@# those shop guys.....
J-Will
#Merica
SW MO
i would like to know how its set up on an 03 denali as well. i would like to do mine this weekend. i clicked on your link you provided, but it wants me to register with the site and it isnt takin my email address? oh well. either way if you could elaborate itd be appreciated :)
heftylefty58
CA
I've uploaded a drawing of the heat shield for my YD:
http://i43.tinypic.com/16037mh.jpg
Other than the 2 bolts at the front of the heat shield, notice that there are two holes at the rear portion of the heat shield: Those 2 holes slip into exhaust hangers. If you check out the thread I posted, you'll see the challenge. Try creating a dummy email account with yahoo if you can register with your current email.
From what I hear, only the 6.0's with dual inlet mufflers have the shield that bolts to the exhaust (as well as the trans). The 5.3's have a smaller shield that only bolts to the trans.
Drgnblood
F%ck Douchebagistan!
Douchebagistan for now
i did it last weekend.....watched the video about 40 times just to have it kinda running through my head as i disassembled......easy as hell except its a small area to work in....once you get them all out clean the pieces that will be reused well and the ***** of it...is getting that spring and the fourth apply piston back in correctly...and then get it pushed back in throw all the pieces back in and when you get the cover back on i used the back end of a long flat head and applied pressure so i could get the snaplink back in....and here was my F up...i didnt ensure the snaplink was seated in the groove correctly....i pulled out of the driveway and drove down my street a few feet and it stayed in first....lost most of my tranny fluid and then the rest of it in my garage when i pushed back down my drive....double checked it...got it seated correctly and works great now....no tranny issues and a nice firm shift...just be careful and you should be fine....
danimalmax
louisiana
its not so bad once u got it all figured out, i even brought my laptop outside with me when i did mine, lol
Grocery Getter
A guy with a truck.
Phoenix, Az
Did the servo install this morning. Guys, this is a piece of cake. Biggst PITA is getting the snap ring back it(and not that hard) and getting the heat shield back on after driving arond and getting the cat hot. It took me a little over an hour and that's only because I was taking my my sweet as time so not to f-up. If I were to do it again i think it would take me 30 min or so now that I know what I am doing. If a shop quotes u more than $25-$30 punch them in the mouth.... This was a seriously easy job......
ELOOSECANNON
North Tazewell, VA
Just ordered my servo today. Can't wait to get it in and try it out.
How do you firm up the other shifts? With another servo along with the vette servo? If so how do they install?
danimalmax
louisiana
i got a 4th gear billet servo to go with mine, u pretty much discard the last piece that goes in and the cover and replace it with your new billet piece which is a combination of the 4th gear and the cover
Drgnblood
is this the piece that you got from oregon??
SUPERIOR 700R4/4L60E BILLET SUPER SERVO 4TH APPLY PISTON AND COVER
and can anyone tell me about shift kits....i saw some on their site but i dont know if i should be getting into that....or they have the high performance tranny rebuild kits....
Buford bubba
