Power Door Locks not working
Kevinmac
Does anyone know if there is more than one fuse that goes to the Power Door Locks on a 1997 Tahoe LT. I know that the A circuit is for the power seats and for the power locks and my power seats work. It states in the owners manual that number 13 fuse is for the cigarette lighter and Door Lock Relay but my number 13 fuse has a short in it and its been like that since I've had the vehicle for six months and my power locks just stopped working last week. If there is anyone with the same vehicle would you mind pulling your number 13 fuse and still see if your power locks work. If anyone has any other ideas could you please get back to me.
99Yuk
Northern Ontario, Canada
Your right, there are two fuses that run directly to the power door lock relays.
I pulled this from a 1997 tahoe wiring diagram that I had found.
I don't know the fuse number of the second fuse though, or which one it is in the fuse panel. You might have to look that part up.
95slowhoe
Boon
When my fuse for my cigarette lighter was blown my power door locks did not work either. I replaced the fuse and all was good.
K
Kevinmac
Fuse keeps blowing
I put two different fuses in the Fuse 13 slot and the fuse blew both times. Just wondering what I should do, when I pulled the fuse there was a 25 fuse in there but it calls for a 20 so I tried a 20 and then a 25 and it blew both times.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Fuse 13 cover, If installed, Power Amp, Rear Lift gate(release switch I believe), Cig lighter, Door lock relay, and power lumbar seats. You Could unplug each component at its connector to isolate it form the bunch to dee if it still blows. But since you not would activate anything intesionally yet start with about 5-10 fuses first.
These might help:
http://www.sunlitcomet.com/images/automotive/162464694.gif
http://www.sunlitcomet.com/images/automotive/62392105.gif
Let me know if you need connector locations.
K
Kevinmac
Yes could you please let me know the connection locations.
SunlitComet
OBS Jedi-Do Good
Match number below with diagram. By doing C212 first you can disabble about evereything except the cigar lighter and liftgate hatch(if installed) at once from your fused supply wire.
CONNECTORS LOCATION
C100 LH rear of Engine Compartment at Bulkhead
C101 LH rear of Engine Compartment near Fuse Relay Center
C102 LH rear of Engine Compartment near Fuse Relay Center, Mounted on Fender
C103 LH rear of Engine Compartment, under Brake Master Cylinder
C104 LH rear of Engine Compartment, under Brake Master Cylinder
C105 (VIN J) Rear of Intake Manifold, near Center
C106 Top of Engine near LH Valve Cover
C107 LH front side of Transmission
C108 (VIN J) RH side Intake Manifold, near Throttle Body
C110 LH rear of Engine Compartment, near C100
C111 LH rear of Engine Compartment, below Master Cylinder
C114 At Convenience Center
C116 LH front of vehicle, near Core Support
C120 Rear of Engine, near Transmission
C200 Behind RH portion of I/P, near Heater Motor, in Foam Wrap
C202 Under Steering Column
C203 Behind RH portion of I/P, near Heater Motor, in Foam Wrap
C204 Behind RH portion of I/P
C205 At Convenience Center
C206 Inside LH "A" Pillar, lower portion
C207 Inside LH "A" Pillar, lower portion
C208 Inside LH "A" Pillar, lower portion
C209 Inside LH "A" Pillar, lower portion
C210 At Convenience Center
C211 Under Driver's Seat
C212 Under Driver's Seat
C213 Inside RH "A" Pillar, lower portion
C214 Inside RH "A" Pillar, lower portion
C215 Inside RH "A" Pillar, lower portion
C218 At Convenience Center
C219 At Convenience Center
C220 At Convenience Center
C221 At Convenience Center
C222 At Convenience Center
C224 LH rear of Engine Compartment, under Brake Master Cylinder
C225 LH rear of Engine Compartment, under Brake Master Cylinder
C227 Under LH side of LP, near Stoplamp Switch
C230 Behind RH side of LP, above HVAC Evaporator Housing
C240 In cross body harness, 100 cm into Seat Belt Switch Breakout
C241 Seat jumper harness under LH Front Seat
C266 LH side of Steering Column, near Bulkhead
C298 Behind LH side of I/P, near Convenience Center
C299 Behind RH side of I/P, above HVAC Evaporator Housing
C300 In Overhead Console
C301 LH front Kick Panel
C302 LH front Kick Panel
C304 Under Driver's Seat
C305 In Headliner at #1 Roof Bow
C306 Under front Seat
C400 RH rear of vehicle, above Auxiliary Blower Motor
C401 RH rear of vehicle, above Auxiliary Blower Motor
C402 Top center rear of vehicle
C403 LH "D" Pillar, top
C404 LH "D" Pillar, top
C405 RH "D" Pillar, top
C406 RH "D" Pillar, top
C407 Beneath LH rear Edge of Bed
C408 (03, S3) Beneath center rear Edge of Bed
C408 (06, 16) Lower center outside portion of Endgate
C409 Beneath rear center of Bed, near Bumper
C410 Top center rear of vehicle
C411 LH rear of Cab
C413 LH rear of Cab
C414 In line to front Dome Lamp
C415 In line to rear Dome Lamp
C496 RH "B" Pillar
C497 RH "B" Pillar
C498 LH "B" Pillar
C499 LH "B" Pillar
K
Kevinmac
I'm going to have a friend of mine look at these diagrams, not to electrically inclined. When I look at the diagram I see that the Power amplifier relay is in the Suburban only. The reason that I'm asking is that my son had a new head unit put in his truck and it seemed that the power locks stopped working after that I believe, just wondering if that could have been a problem. I also see that these diagrams are from 1996 but I imagine that they would be the same for a 1997 Tahoe. The cigarette lighter has never worked in the vehicle since he's owned it and it doesn't have the liftgate hatch. Why would I start with 5, 10 fuses after I unplug C212 because then there would be nothing active on the circuit. Also where is the convenience center located. Thanks for your help.
SunlitComet
OBS Jedi-Do Good
I forget where exactly but there is supposed to be a power door lock reley in the dash. Perhaps it messed with the radio install?
I recomended small fuses becuase if it shorts out as soon as you plug it in I was concerned that with high amp fuses that it may stress the wire to much and too many times with those high amps and may eventually cause a fire.
When the problem gets fixed where it does not blow any more I would be safer to go back to the original fuse.
Just trying to find a safe way.
K
Kevinmac
Where is the power door lock relay on a 1997 chevy tahoe located
Could somebody telll me where the Power Door Lock Relay is(forget where exactly but there is supposed to be a power door lock reley in the dash. Perhaps it messed with the radio install?) My son took off his dash to put in new head unit and Power Door Locks have not worked since, could this be my problem.
SunlitComet
OBS Jedi-Do Good
I found it.
From alldata:
The Power Door Lock Relay is located under the center portion of Instrument panel (I/P), near Remote Control Door Lock Receiver (RCDLR).
NOTE: This relay is used only on 4 Door and 2 Door Utility, Crew Cab/Suburban.
The picture shows a wire bundle with a relay plugged in and the relay has a stem that sticks into a mounting hole
paladin
Hi ,
I have a problem with my 97 hoe LT 4 door. I really appreciate if somebody can help me.
I had a remote starter on it which had a poor range and some problems. I bought a new 2 way remote starter with keyless entry and installed it. I removed the dash panel and all the buttons (head light switch, tail gate and viper buttons). I tested it before I plug everything back in and everything worked just fine. I began to put everything back together. When I plugged in the headlight switch the doors began to unlock and kept unlocking until I unplugged the battery. I unplugged everything from the remote starter but my left door was not locking from any of the buttons and when I pressed unlock it was unlocking 2-3 times. (I found the mistake I did, it was the dome supervision relay I put which supposed to supply - and I gave + 12V the fuse before the relay was dead). I checked the fuses in the driver side and under hood fuse boxes and everything looked fine. I disassembled left driver door and checked the actuator and it is working fine. I checked the lock/unlock relay right of the steering column and that looks fine. Suddenly my left door began to lock but it is still unlocking 2-3 times and also when I press the door supervision button next to headlight switch the door keeps unlocking (only the drivers door and I believe thats what happened fist time I plugged the headlight switch) Right door is locks sometimes halfway but not unlocking at all but it looks like it is trying.. So I decided to try the lock unlock manually without the relay module. I gave grey and tan wires +/- 12 Volts and the symptoms are exactly the same and I heard I relay being pulled somewhere in the steering column but I couldn't figure out where it is coming from. From the electrical drawings looks like the "keyless entry module" has the control of the left door motor and has a parallel line is going to the right door motor . So
right door motor is connected both to the relay box and to the keyless entry module.My question is where is the keyless entry module or what is it looks like? I already unplugged the silver box next to the relay box but didn't change anything.
I couldn't find a replacement for this module online and since I have the keyless entry already built in in my remote starter can I just unplug it and forget about it? (It looks like it also "controls the interior lights system" but I am not sure how)I already tried Circuit breaker A but it is still doing the same thing. Any ideas???
Thanks
Kevin
jzaldivar
Lemoore CA
keyless Entry
the only way you would be able to use the keyless entry if you unplug the aftermarket remote start is to use a factory remote, I hope i understood your question correctly, on my 06 silverado I am able to use the aftermarket remote(Viper Alarm) and oem remote. Lots of installers cut corners and just piggyback the aftermarket equipment to your oem wiring in other words the just crimp the wires and tap into the oem alarm(wiring) to avoid rewiring anything. So unplugging the afteramarket alarm will just disable that and not your oem k-less entry. Hope this helps.
Juan
paladin
Juan
Juan,
Thanks for the reply. I installed the remote starter myself and I believe that's the problem:). I didn't cut any wire. I found the the wires coming from the driver side door lock unlock button. There is connector just above the carpet, on the left wall. I connected my aftermarket keyless entry cables with two relays to these cables. I believe my only mistake was to connect + to the dome circuit. Last night I checked the right door motor and looks like it is not working right.. I took the entire right panel out and gave + - 12 volts to the motor directly. My left door began working after this but looks like right one is gone. After your reply I found my original fob which doesn't work well for the last 5 years. Looks like it locks and unlocks fine all the doors except the right door which is normal with that motor.
My problem is still the same. With the remote starter/after market keyless entry unhooked and all relay fuse removed ( I used 1 for lock 1 for unlock 1 for dome lights and 1 for rear hatch) when I press any unlock button in the car the driver door tries to unlock 2-3 times and when I press the dome supervision button (bottom left of the headlight switch) the doors keep unlocking (which was caused all the problems)..
I looked to the diagrams and there is a relay box under the center of the dash board (which I tested and works ok) .
The left door lock unlock goes to a relay box AND keyless entry module and the right door goes directly to the keyless entry module I have no idea about the rear doors. My guess is this 2-3 unlock pulse coming from the keyless entry module. I unplugged the relay box and connected +12 and ground directly to the door motor cables. I still could hear a relay pulled somewhere under the dashboard and I believe it is the keyless entry module and still the driver door unlocked multiple times. By any chance do you know where this module is?
Thanks again for the reply..
Regards
Kevin
cadillac3646
keyless module (rcdlr)
Hello paladin, were you able to get to the keyless module? If so, would you mind telling me all about the process? I'm pretty sure mine needs to be replaced. It won't go into program mode. I have a 2000 Z71 old body style w/ 5.7 Thanks p.s- will you sell me your old one?
paladin
Hi,
I believe mine is not in great shape either.. I think replacing that with an oem product is much cheaper and easier.. I can try to help you with the process but as you can tell I had some problems with it myself. I connected +12V instead of ground to the dome lights and something is broke now. Looks like one of the doors is directly connected to the relays and the keyless entry module ( i believe it's the left door) the other one is connected to the KEM only and I believe KEM is pulling the relays. (they are in the center of the dash).
I found a silver box next to the relays in the center of the dash.. I unplugged it but still my driver side door tries to unlock 2-3 times and sometimes the switch doesn't work at all. I still hear a relay pulling somewhere under the dash I believe that silver box is not the keyless entry module and have no idea what it is.. I checked the right door actuator and it doesn't pull or push all the way and sometimes it moves just a little. I gave the 12V from the door panel switch I will try to give it from another source but I believe those wires are always hot..Probably need a new door motor.
There is still something wrong and I still don't know what it can be.. I put everything back together last night and I will try again this weekend. Does anybody has any idea..
Thanks
Ratna
Suburban may be the same, but mine was a breaker, not fuse. 30 amp metal, it controlled the seats and the window locks. I got a generic one a parts store and had to trim the brass tabs so that it would fit, now all works. When it was out I could hear the lock relay click but the locks wouldn't work, now with the new relay they work. It is located in the fuse box inside the drivers door
SuburbanPassion95
