Cruise control stopped working
Abstrastic
Ft. Worth
I noticed about a week ago my cruise control wasn't working anymore. So I have checked all the brake lights and they work. I have checked the fuse on the drivers side part of the dash. I am out of ideas does anyone know of another fuse or something else that would cause this?
Truck is a 2004 Tahoe Z71
Rivieraracing
When you say all brake lights work is that including the 3rd brake light? Also, spend a bit of time and one by one check EVERY fuse to make sure that something with the CC doesn't share another circuit (trust me, its a common thing to have some circuits share fuses and for them to not be a part of the label, gotta love GM!).
Abstrastic
Abstrastic
Ft. Worth
Yes that includes the 3rd brake light.
I will check the fuses again.
Anything else?
trev
Does "cruise" illuminate on the dash when you press the button? When I first got my truck it would light up but never work. It didnt bother me too much. One day while doing the oil, i noticed there was a cable hanging on top of the motor. it was the cruise cable. Not sure how or why it fell off, but works fine now. HTH
---------- Post added at 09:13 PM ---------- Previous post was at 09:12 PM ----------
And my 3rd brake light has not worked since I have had the truck
Abstrastic
Abstrastic
Ft. Worth
It did light up when it worked before now it does nothing.... Can you take a pic of the cable you are talking about?
Rivieraracing
Like I said, check every last fuse you have on your truck, sometimes it's a simple fix!! I know from experience, went in to the dealership for a different problem and I personally watched the head service tech spend 45 minutes trying to figure out the problem, he checked all the fuses for that peticular item and tested everything under the sun, then stumped and pissed he went through EVERY fuse and check them one by one and found one burnt out for another circuit, replaced it and it fixed my problem!!
---------- Post added at 06:55 PM ---------- Previous post was at 06:51 PM ----------
If I remember right I had a brake controller for trailer installed by them and it quit working on me so I took it in to them to fix it!! When the controller stopped working so did my 3rd brake light as well as the CC, not saying the same fix would work for you but it did take the guy to start pulling unrelated fuses to find the blown one! Good luck and keep us posted!
sanddperformance
I would check fuses also it could be a tac module but I would think your pedel would not work if that was bad
ID_Escalade
Boise, ID
Did you add any led tail light recently, or put led light bulbs in the stock housing if so that could cause the cruise control to not work
Abstrastic
Abstrastic
Ft. Worth
Ok so I just checked all the fuses and all of them are good to go.
---------- Post added at 06:49 PM ---------- Previous post was at 06:47 PM ----------
I did just install these:
http://www.hidguy.net/index.php?main_page=product_info&cPath=534_75_301_467_469&products_id=458
How do I go about fixing the issue?
---------- Post added at 07:40 PM ---------- Previous post was at 06:49 PM ----------
Ok so I just swapped my old bulbs and taillights back in and went for a drive and sure enough my cruise control works. So it is the taillights I bought now my question is how do I fix the problem without having to get rid of the led taillights?
ID_Escalade
Boise, ID
that could be your problem you might want to e-mail them and ask them if that would cause the problem, they might need diodes or resistors im not sure i know there are a couple of guys on here that know what they need if it is the problem. You could put your old lights in just to see if the cruise control works and if it does thats your problem
Abstrastic
Abstrastic
Ft. Worth
I posted this last night:
ID_Escalade
Boise, ID
You might want to search led taillights on the forum there are a few and they tell you what you need to fix it, i think its a resistor that you need but im not positive you might want to look at a couple of the post, there are a few guys on here that know what you need and they know why more about the led tails then i do.
bkboatnsleds
McHenry, IL
Odd - I just installed my LED's and did not have any issues.. But I did read on here some people did.
Layzieyegunman
San Bernardino, California
The same thing happened to me with my 04 tahoe... it just stopped working out of no where .. no light no nothing, then a few days later i tried it again and it worked fine. Then a few days after it stopped working again... Then I was pissed so I kept messing with it pushing the button over and over again and it started working again. It has worked ever since that was back in july of this year... Sorry if this dont help much but thats my story
Abstrastic
Abstrastic
Ft. Worth
Well I think I know what the problem is so I emailed and called hidguy.net but know one will return a phone call or respond to my email.
johnsonwillie199
