TBI guys.. ?
AtomicHoe094
Atomichoe094
cleveland, OH
JKmotorsports
Austin, TX
The pulleys help by letting the crank spin the accessories easier, kinda like changing the gears on a 10-speed bicycle. The smaller the drive pulley, the less effort it takes to spin the rest of the pulleys, freeing up some hp.
As for chips, the only thing you can do with TBIs is replacing the eeprom with an aftermarket chip programmed with the mods to your set-up. Superchips can burn a custom chip for you.
A
AtomicHoe094
Atomichoe094
cleveland, OH
would it be worth while to put on my truck? I say this because im getting a volant CAI, and this guy has more items for sale on ebay and i checked em out.. he also has a TB spacer and the pulleys, he said he would give me a really good price if i bought all 3.
haks310
Got LEDs?
SoCal
I've read up on the pulleys and read up on experiences guys over at FSC have had with them and most were not impressed. I would skip it and just look into getting the intake and spacer.
A
AtomicHoe094
Atomichoe094
cleveland, OH
even a spacer most people would veer from them. but you never know until you personally try something out you know.. im looking to free up some more hp from my truck tho. im looking into that volant CAI then i think if its a good deal the spacer. then ill shoot for headers and maybe a cam. then a custom chip
JKmotorsports
Austin, TX
I agree. For the money, it doesn't make much of a difference unless you're trying to get the most out of your car for e.t. and trap speed. On a DD, that same money can be better spent elsewhere imo.
JKmotorsports
Austin, TX
The spacers on tbi and carb motors can be beneficial where they can help atomize the fuel better since the injectors/jets spray before the spacer. But I would never use them on a dry type system where the injectors spray downstream of the tb.
haks310
Got LEDs?
SoCal
Actually if you read up on FSC and GM FullSize you will see that a lot of the people run them and have positive things to say about them. I would do the intake, throttle body and injector spacer. Then look into the headers, y pipe, cat and muffler if you have not so already.
bowtiefreak
No Quarter
Near Philly
My vote is headers, even a cam. The custom chip will help too, but do your other mods first and have the chip set up for them.
A
AtomicHoe094
Atomichoe094
cleveland, OH
dont need emission. : ) i have my dads dealer plates.. hehe but that would be a sick as **** motor tho wouldnt it?
bass1775
Maryland
I have underdrive pulleys on my truck. I've never had it dynoed so i can't say for sure they work but, the theory is sound. However, the downside is you have to careful with the alternator turning too slow especially if you have heavy electrical requirements, ie: big systems. A way around that is to purchase an overdrive pulley for the alternator if you install the underdrive pulleys. I have a powermaster alternator and this is what they recommended for my solution after repairing the alternator. Haven't had any problems since.
Bad bow tie
Grizz Straight FTMFW
Michigan/NC
So if you do end up doing these mods, post your results. I also thought about doing this to my TBI, but with either a K&N intake or Airade (cheaper) with probably an Airaid TB spacer. Just costs a small fortune and the results I may see are detering me a bit. Also thought about getting a chip burned from TBI chips. Anybody running a set up like this or a TBI chip?
haks310
Got LEDs?
SoCal
You'll notice a greater throttle response and about a gain of 2MPG. I would to the injector spacer as well. Haven't gotten the chip out the way, going to do that when I finish the exhaust; headers,cat and muffler.
JamesinAbilene
