Installed Janzer Performance Fully Ported TB
foreverfalcon40
Took me an hour to install as well as do an oil change on the Hoe.
To be Honest with you...really don't feel that much of a difference on the intial test drive. Maybe after a few days of cruisin I'll notice something.
I did some measurements and it is def bigger then stock from outlet to inlet.
I also managed to kill my MSD 6al box when it touch the positive side of the battery cable.
YIKES!
Returning the OEM TB for my core deposit and sending out my MSD box to MSD to get rebuilt...
FUEY!
I can do a write up if people want.
---------- Post added at 05:55 PM ---------- Previous post was at 05:51 PM ----------
Top oulet is 3 3/4in and the bottom inlet in 3in on the Janzer. Oem top outlet is 3in and bottom is inlet is 2 3/4in.
Super clean TB thats it.
foreverfalcon40
foreverfalcon40
Only me Babe...
forget to mention my EVAP is leaking...Nah can't be the 2nd one thatd be too easy.
Its the 1st one inside the dash. 5.3 hrs on ALLDATA and I have to remove the steering column. Nothing is ***** easy on this truck something simple as LED tail lights its a day affair!
---------- Post added at 03:49 PM ---------- Previous post was at 03:47 PM ----------
Not much of a difference?!? Is your intake tube/filter stock? Mine was when I did it.
Hahahah I feel insulted...LOL
I got the best there is for our trucks PERIOD
VOLANT and some
---------- Post added at 03:52 PM ---------- Previous post was at 03:49 PM ----------
Ok so after I cooled down...I drove it last night and today this mourning. I can defenitly feel the difference in response and take off due to the TB. I have to relearn how to drive...
If I gas it as if I had the OEM TB off the line cruising b/w the TUNE and B&M shift kit she really jumps. Kinda annoying...but the performance is there. MPG...not sure yet...feel like it hurts!
destroyer1362
A work in progress
Midlothian, TX
I wouldn't worry too much about mpg. The tb swap was a last minute repair (the oem was sticking open.. very bad!!) took mine 300mi to houston and back cruzin' between 75 and 85 the whole way got around 18/19 mpg. City driving seemed to improve and if not it didn't get any worse lol
Does it feel like it tries to stick shut when coming off idle? Just curious mine did it for about the first 20mi.
foreverfalcon40
foreverfalcon40
Mine feels like it stuck shut going from idle to rpms when driving hence the buck from a start. I also think the spring on TB has to be the culprit. Mine had 115k on it when I swapped it out. It was worn and stretched out. The spring on the Janzer one has more coil on then the OEM one and is tight.
hoondueces
Hey falcon. Would u still be interested in doing a throttle body write up? I have mine comin in the mail
97GT
Bay area, Ca
hey how long did it take you to get you TB. I ordered mine over a week and have not received a confirmation that its being shipped. I emailed the guy asking for a tracking number and have received no response.
foreverfalcon40
foreverfalcon40
Hell yeah! do you hav basic tools? and star keys?
---------- Post added at 07:25 PM ---------- Previous post was at 07:24 PM ----------
mine took 2-3 weeks...just keep emailing him.
just ait to see how long it takes to get your core charge back...lol
hes good peeps so far!
99Yuk
Northern Ontario, Canada
So I brought the truck into our garage this morning, and had the apprentice look at it to see why the new TB was sticking on idle.
He says it's because the butterfly plate is machined so close to the ported TB that is scratching the inside of the TB a bit off idle(closed). He pointed to the new score marks inside the TB to show me where the butterfly is gouging the inside of the TB. He figures that after a few more days of this, that things will settle down and be ok.
Funny that when brand new and shiny, you can see the polisher marks on the inside of the TB, and after only ~60kms the butterfly valve is scratching up the inside pretty good and that's why it's sticking, and the accepted solution is to let the butterfly continue to scratch up the inside until the grooves are well worn and the stickyness stops. He says that brand new GM's do this too utill the first few hundred kms or so. IDK.
Where do those metal particles from the scratched grooves go?
bai78
Surviving
Dallas, TX
In the loop, under the valley, & maybe eventually on your drain plug magnet.
I dunno.
destroyer1362
A work in progress
Midlothian, TX
You guys have had your TB for a few weeks now. Did the stickyness go away?
I'm not liking the bucking starts...:emotions122:
I've had mine the longest, it goes away. It will get to the point where you will feel it sticking but your acceleration will be smooth and controllable, it just gets better from there.
andrew383
indiana
Hope everything works out for you guys..Scott is a big tool!!! Id never recommend his products or services to anybody.. Google jantzer performance and you'll see why ;)
IMO he's over porting the TB and its allowing the blade to close more resulting in the sticky issue... He's been to over port TB's before..
99Yuk
Yup, that's what my Mech told me too, but the butterfly blade will score the TB walls and settle down, and after waiting a few days, it's working perfectly fine now.
... He's been [known] to over port TB's before
Ummm, isn't that a good thing? The way I figure, isn't that what we paid for?
Anyways, I have NO complaints about Scott's work. I was a bit leary at first, but I say now, if your on the fence, go for it!
---------- Post added at 08:46 AM ---------- Previous post was at 08:45 AM ----------
Yes I do
You can do this! If I can do this by myself, you can too! Those instructions are very good! You'll be fine and you will be done in 30 minutes.
briannorris
