Weird brake pedal "abs" feeling
stevek
Dallas, TX
So there has been a problem in this Tahoe for a while. The first time you use it after it's been sitting overnight (or a long period of time), I'll be backing up going down the driveway (doesn't happen when shifting) and I'll get the feeling like the ABS is "clicking" the brake pedal if that makes sense. I do lose a lot of braking power when it happens and I have to pump the brakes or I literally have next to no brake power. I don't quite know where to start.
Should I bleed the brakes?
Dealership says they can't reproduce the problem :emotions122:
Modded
That Guy
Bleed the brake and that issue will be gone, also assume you check the brake lines for leaks and the brake fluid.
I hate when dealers give that dumbass "cannot reproduce" excuse. Like someone would really come out fo their way to make something up.
S
stevek
Dallas, TX
Especially when I spend $15 in gas going up/down a mountain to drive to the dealer. I'm just going to tell them what to do and have them do it. Fo free!
Jay
I'm not sure how the trucks/SUVs detect wheel speed, but if it's anything like my old LT1 camaro there should be sensors in the front wheels that the PCM uses to detect slippage. I had it happen a lot over the course of 10-15k miles until i crawled under there, found the sensors, unhooked the harness (right off the back of the hub), sprayed it out with brake cleaner, squirted dielectric grease in the harness and plugged it back it. Didn't do it again during the last 80k miles i had that car.
Might be worth it to roll under there and check to see if such sensors exist. I've never taken the time to look to see if mine has them... gotta change the oil in the next couple of weeks I'll look while it's up on the lift. You should see a wire harness in there somewhere. Unless it references it at the differential or something.
macky
i have this happening now too, any resolution yet?
900sub6.0
Alberta, Canada
We have dealt with this problem a few times. Very hard to duplicate the issue. Are you by any chance turning when this happens??? If so, it could be your steering position sensor acting up. If the steering position sensor malfunctions the stabilitrac/abs will kick in without codes.
S
stevek
Dallas, TX
nope, usually backing down my driveway when I first get in the car for the day... it's a steep incline and dead straight. ABS/Stabili light doesn't go off
crazyikon86
i know this is from the dead but i have the same problem. any fix. im thinking speed sensor but dont have a tech2 to check them. i might try to bleed the brakes this week.
GM Customer Service
Michigan
Hello,
I am sorry to learn you are experiencing an issue with your vehicle, crazyikon86. I know you are looking for advice on how to resolve the issue yourself and I might not be able to give any technical advice but I just wanted to stop by and let you know that GM Customer Care is here on the forum and happy to assist if you ever have any general questions or concerns about GM products.
Jennifer T.
GM Customer Care
2007tahoe
Mine does it under the exact same scenario. Prob only like once a month.
enigmaspeed27
