pulled the trigger on the corsa sport
Jr_454
Minnesota
its taken me 9 monthes but i finally saved up enough money and ordered the sport, its back ordererd but i should get it in 2 weeks, damn thats gonna be a long 2 weeks.
Rivieraracing
That's great man, you will love it!! I've had mine since this winter and absolutely love it, very high quality system!! How much did you buy it for?
J
Jr_454
Minnesota
765 deliverd, did you install it yourself or have someone else do it? any ideas or tricks on the install
Rivieraracing
I installed it myself, it was pretty easy to do just took a bit of time to make sure everything was just right!
J
Jr_454
Minnesota
nice to know. Did you cut the exhaust or did you pull it out in one piece, What did you use to help get the exhaust of the hangers. Someone told me vasaline worked pretty good.
TqMnster
Monroe, NC
If you dont have acces to one of those hanger tools just throw you some grease or vaseline on the end of the hanger and a pair of big slip joint pliers. One side on the tip of the hanger and the other on the rubber and it'll slide it over the hanger enough you can slide it by hand. A torch can help loosen up stuck exhaust pipes sometimes by heating the outside pipe and letting it expand a bit. Just be care not to burn yourself or use it around any fuel lines obviously lol
TqMnster
Monroe, NC
Yeah I bet... I looked it up on youtube and holy cow! But cant justify the money for one :( I'll settle for my spintech setup which in the end will only cost me roughly 180 with tip and new pipe installed :)
Rivieraracing
Yeah the hangers were no big deal for my install, can always put a little grease like mentioned earlier to get them off!! The problem I had was undoing the flanges in the front of the exhaust, they were sooooo rusted on that I had to break them both off and get replacements from the dealership! Take a look under your truck and check out what I am talking about, might wanna buy replacements in case you run into the same problem, they were cheap!
J
Jr_454
Minnesota
Thanks Ill have to do that, I would be mad as hell to have to wait 2 weeks for delivery just to break some bolts off and have to wait another day. It was expensive but i have pretty much stopped doing anything fun lol to save up for this. besides the videos of it make it sound so good.
Sasquatch
Orange County N.Y.
I would start hitting the bolts with some rust penetrant now, It gives it a while to work in. P.B. blaster is the best stuff i`ve ever used. i always do it and most times it works well.
J
Jr_454
Minnesota
sounds good ill hit it tonight when the kids go to bed, I really bought it for the sound but has anyone noticed any gains anywhere with this system
J
Jr_454
Minnesota
does the kit come with the gasket need when you clamp it to the cat flange?
Rivieraracing
I don't quite remember but I'm leaning towards no, I don't remember mine coming with one! Might just have to wait for yours to come before you go out and buy one!
J
Jr_454
Minnesota
does the kit come with a gasket for the new pipe and the exhaust flange
Drewphil
