Front shock bottom mount ( replace rubber bushing ? )
mountie
After replacing my front shocks, we found the left- bottom rubber bushing, attached to the A-arm, is cracked. The shock must be moving because of the bad bushing.... How is it replaced?? ( 2005 Yukon XL - 4WD )
  • L : F shock.jpg
    L : F shock.jpg
  • L : F Lower shock mount.jpg
  • L : F shock mount grommet cracked.jpg
noodlesandsam2
NYC Metro
look for shock mount bushing - Moog has them. a bit of a pain. remove the shock, and get a bushing press in there to remove and install. I think you will have to experiment a bit. I've not done this, but I'm now going to look at mine this weekend
mountie
mountie
Thanks..... I am not noticing any issues, because of the bad bushing, ...Maybe the problem is slight? Maybe it might seem better when it is replaced? Hard to tell, but I don't like worn out stuff.
Thanks for reminding me about Moog.
Donal
Americus Georgia
Looks like the Oreilly's supply chain is about empty. Moog K6724 But Walmart offers them at 18.00
HansJr
Waterville, Maine
Did you end up changing them?
bibleman2081
Did you ever change front lower shock bushing? getting ready to do this this weekend dint know if you had any tips?> thanks
mountie
mountie
Nope..... the bushing is still there.... I don't know how difficult it is to remove.
But honestly, I haven't noticed a problem as I drive.... the rubber is cracked, but the shock is well bolted to it. The rubber doesn't seem 'destroyed'...... just cracked....
Removing it..... as other bushings, like this one, I don't know if a hammer & socket will 'punch ' it out, or a torch to soften it, then knock it out.
A muffler shop or a suspension shop may advise you.
SnowDrift
Yesterday, i learned my lower shock bushings were trash on my '05 Tahoe with 344,000 miles on the ticker. I had been noticing noises from the front when going over harsh bumps like manhole cover, railroad tracks, etc. I put it up on a lift and found the rubber was completely gone on the bottom side.
I found this thread while looking for information of doing the job. Since it didnt seem to lead to a finished product, then maybe this will help others.
I called Advance and they were able to order the Moog parts at 8:30 at night for me to pick up at 7:30 this morning. Worth noting, one box is a set to do both sides.
To get the old ones out, we removed the lower shock bolts and tied them to the upper control arm with a zip tie on each. Then we took a long round punch with "crisp" edges and folded them inward using hammer and chisel. Keep in mind the rubber that was left, we removed beforehand.
We cleaned up the holes with light emery cloth and coated the bores with anti-seize. The new bushings can be driven in using a large impact socket and sledge hammer. We had part of a rented tool set with which we drove it but still used a sledge. The rented bushing driver set was of little value aside from this since it simply would not fit with the whole chassis still intact except for the shock.
Maybe there is a press set that would yield easier results when doing the work in the vehicle.
I will call to find out on Monday what it would cost at a local shop i trust since i dont know if i would do it again and we have two more vehicles with the same ludicrous design, although those are not yet in need of replacing.
mountie
mountie
I had the arms replaced…. ( so all points of contact are new )…..
Slamming a big hammer against it, sideways? That may tweak other mounts?
SnowDrift
I'm open to ideas on how to press them in because I would imagine that they might need done again since the originals only lasted just over 300,000 miles. However, I didn't find much information on the subject.
mountie
mountie
Plan on a transmission or engine replacement before those bushings get worn out…….. AGAIN…. :)
Durobans
