Ac Cooling
JoeBoxer1130
2003 Tahoe LT
Does anyone know why my ceiling AC vents blow out colder air than the front vents???
Im not low on coolant last time I checked.
Any tips will be greatly appreciated.
TJ Baker
Colorado
2003 Tahoe LT
Simplest answer is the two vents come from different evaporators.
The air from the ceiling outlets comes from the auxiliary system and the air from the panel vents comes from the front system.
Further, the front system employs a fixed orifice as a refrigerant meterimg device and the auxillary system uses a thermal expansion valve.
A TXV (thermal expansion valve) system can maintain better control of the evaporator core temperature than a fixed orifice system can.
That's my guess....
PG01
Up here to the right
That's my guess....
Pretty got-damn good guess if i do say so myself….;)
mikez71
Could said fixed orifice be clogged, causing sub optimal cooling?
Hopefully relatively easy/cheap to replace? (though still requiring a charge)
If the front blend door actuator was failing/partially stuck? .. are you able to blow heat in the front?
And are you on recirculate?
I once noticed fresh air was really warm with my A/C off, though I was missing my cowl seal at the time..
J
JoeBoxer1130
Yes, hot air comes out when I bring it up to 90F
Tupapi
