[SOLVED] How to unlock?- Replacement seat belt arrived wound up tight & locked
Newokie59
Keeping it short. Ordered 2nd row driver side seat belt w/retractor. The retractor was wound up so tight I can't get it to release. Is there a hidden tab/release? Any ideas? TIA
2005 Yukon SLT
2005 Yukon SLT
it has to be tilted at the exact same angle as it is when installed in the vehicle, it's kind of like a trick box.
if you can't get it just keep trying eventually you will, just how they are designed.
Newokie59
Newokie59
Man oh man! That was the trick. I was able to force about 1/2" back into the retractor and very slowly I was able to get the belt to unwind. I attached a small c-clamp to the belt so it won't retract anymore. Thank you so much @Doubeleive!
jkhuntzinger
