hatinthering
- Joined
- Dec 30, 2023
- Posts
- 23
- Reaction score
- 37
2015 Tahoe, 5.3, 215Kmi. Did the full DOD delete myself at around 200K (BTR cam/lifter kit plus retune), all running like new up until about two weeks ago.
Getting a random (but becoming more frequent) CEL with 219B and 0306. I have swapped coil, plug, wire between cylinders, but misfire stays on Cyl 6.
LTFT at idle is way high on Bank 2 at 20-23%, decreases significantly (below 10%) at cruise/under load.
This is screaming vacuum leak to me, which I have yet to find...next step is to pull intake, maybe bad seal on #6 intake port? Any other Bank 2 or Cyl 6 common vac leak places to check?
If no vac leak, is it reasonable to assume bad #6 injector as the only remaining likely culprit?
I have not yet tried a new O2 sensor for bank 2, mainly because the misfire is consistently showing cyl 6 only.
Thanks for any advice!
