Misfiring number 3 cylinder
Manq
Good afternoon everyone,
I have a 2015 GMC yukon denali with a 6.2 L engine that has a misfiring code on the number 3 cylinder. I have checked for spark from the spark plug and the coil, I found no problem, so I replaced the spark plugs, coil, and wires anyway, misfire still is still happening, then I went to the injectors and replaced them and the fuel rail, (do I need to say why I replaced the fuel rail). Anyway I still have the misfire, any thoughts and help would be appreciated, thanks.
Welcome to the Forum from NH.
Pics of the truck, please.
You've been unsuccessfully firing the parts cannon so far, so its time to collect some data. Take the truck to your local auto parts store and ask them to put their scanner on it and see what Trouble Codes exist. That will help us help you resolve your issue.
M
Manq
Miami-dade, since i'm new to the tread what does (Moved you here from Site News) mean?
M
Manq
Thanks Joseph, I do have a code reader and it shows a P0303, number 3 cyl missfiring that is the only code.
It means that as a moderator he moved your thread from "Site News" to this one, so it would be in the correct year and sub-section for your issue.
Forum tip: to tag someone first enter the "@" sign, then start typing the member's name. Like this: @Miami-Dade. You can also "Reply" to his post like I did here. Either way he'll get a notice. Otherwise there's a likelihood that he won't see your comment.
Any update on this one?
Also, does it misfire all the time or only at higher rpms? Could one of your valve springs gone weak?
spectol
