KMeloney
- Joined
- May 2, 2009
- Posts
- 3,476
- Reaction score
- 721
Have you put the 6.2 in Sport mode like you have the 5.3??
Loving my '23 with 6.2.
Testing driving sounds good, but most dealers will not have the needed octane in the 6.2 fuel tank. You probably can still feel the launch difference or measure 0-60 or 30-80 times with several free apps.There is probably a real weight difference in the 2wd rental and the 4wd you test drove and trim can also make a weight difference. You also make a good point about the computer retarding timing for inadequate octane. I also agree that a 2wd rental may have different gearing than a 4wd vehicle. Just my opinion, but if you want a true side by side comparison, I think you need to test drive identical vehicles with the different engines.
For what it's worth, I've had 3 4WD Tahoes and 1 4wd F150 - all of them acted this way in 4 low. 4 low is meant for low traction situations where you need max torque. Be careful using it in situations with high traction as you can damage the system.Another example, the 4WD low doesn't work like I expected - makes noises on tight turns / unexpectedly jerky / not really useful so far but 4WD hi works OK.
Yep, that's what I'm finding out. I pull a 5500lb trailer over my front lawn out to the street. I have a 'grass driveway' with 9" stone and those plastic grids with 1-2" dirt/grass on top. Slight uphill to the street.For what it's worth, I've had 3 4WD Tahoes and 1 4wd F150 - all of them acted this way in 4 low. 4 low is meant for low traction situations where you need max torque. Be careful using it in situations with high traction as you can damage the system.
**Disclaimer** I’m not a professional off-roader but have done it a time or two. More than a dirt trail. Less than the Rubicon trail.Yep, that's what I'm finding out. I pull a 5500lb trailer over my front lawn out to the street. I have a 'grass driveway' with 9" stone and those plastic grids with 1-2" dirt/grass on top. Slight uphill to the street.
Normally I just 2WD over the grass to the street but due to tons of rain, the left rear tire slipped in the grass->mud and I wasn't moving. Put in 4WD-Low and slipping (left rear) tire spun a bit -> 'clunky engage' -> more clunks -> general spinning / could not move forward and tore up the grass a bit more.
Put in 4WD-Hi and pulled right across the lawn to the street.
I don't understand 4WD-Low as it seemed (to the inexperienced! here) that it would be the preferred way to power forward at 2mph over a short distance with the trailer in tow.
I purchased a new ‘23 Tahoe w/the 6.2. Currently 43k miles, had the recall check done several months ago, and was told it passed. BTW I changed the oil to O/40 long before that, and have had no issues. The dealer service advisor told me that they had a failure vehicle with 48k and one with 7k. My nephew has a ‘23 Escalade with the 6.2 and it failed at 53K as he was driving on the interstate (was not fun). Like another member said check all the service records and (not sure if this makes a difference), but I change my oil at max 5k miles and sometimes sooner. This is my 2cd Tahoe, and I owned 2 Yukon XL’s - all with 5.3’s. I truly like this vehicle a lot, and my dealer has a “warranty forever” as long as I service it there, so I’m fortunate there. Tough decision for sure!2023 Denali with 42k miles - what should I watch out for?
6.2 is running strong and still has 18k left on the powertrain warranty - should i assume I'm safe?
I'm coming out of a 5.3 Tahoe with 110k miles, but all I have heard is the issues with the 6.2
Appreciate all replies - bring it on!
Very likely I pull the trigger on this one today - one minor accident and 1 owner.
What warranty company and package did you buy?BUY an extended warranty! We purchased our Yukon w/50K miles at dealer and more than paid for itself!
