Buzzing noise after a bump?
treehan77
TYF Fiend
Crestview, FL
Need some help. Twice now I’ve hit a large bump (railroad tracks) and hear a loud buzzing from what seems to be in the dash or possibly firewall area. It lasted about a second and a half. Best way I can describe it is the alarm from an old washing machine or dryer buzzing you that’s it’s done. Don’t notice any other symptoms, everything seems to working still. Ideas?
Big Mama
Virginia
Any dash lights during this? It almost sounds like either a tire rub. Look at your inner fenders for a rub mark. If it’s an electronic sound see if your battery and grounds are secure.
treehan77
treehan77
TYF Fiend
Crestview, FL
Definitely not tire rub. That doesn’t sound like a washing machine buzzer, and I redid all the shocks etc a while ago, had these tires for a couple of years. No dash lights, headlights were not on because it was sunny.
Big Mama
Virginia
Ok sounds even more like a possible ground or wiring issue. These rigs are known to have grounding issues. The bump may be what starts the process. Check your battery grounds and the one by the passenger foot well.
treehan77
treehan77
TYF Fiend
Crestview, FL
Still monitoring. Still only happened twice. Best guess is stereo, who knows. If it would happen, I’d try with the stereo off but for now, I guess I wait
Marky Dissod
Still monitoring. Still only happened twice. Best guess is stereo, who knows. If it would happen, I’d try with the stereo off but for now, I guess I wait.
Once is never, twice is a coincidence, thrice is too often.
How long does this loud buzzing last? Less than 1sec, or more than 2sec?
treehan77
treehan77
TYF Fiend
Crestview, FL
probably about a second a half. The first time it happened I wasn’t even sure it wasn’t sparking else’s car. Second time I had a passenger and we both knew it was mine for sure. Went over the same railroad tracks 4 times this weekend, couldnt reproduce it
treehan77
treehan77
TYF Fiend
Crestview, FL
As good a guess as any I suppose. I have replaced a few of them over the years, last was the mode door one I think
treehan77
treehan77
TYF Fiend
Crestview, FL
Buzzed at me for about a second again, this time just changing lanes. Wasn’t the stereo, was listening to a podcast it wasn’t interrupted or anything.
Marky Dissod
Could it be your lane keep assist setting?
Think of all the skills that we failed to pass down to next gen drivers ...
ABS? You were going too fast, dumbschidt, and pay better attention next time; every surprise is YOUR FAULT. Traction Control? See previous, buy better tires next time.
Stability Control? See previouses again, buy aftermarket suspension parts. What, you NEVER did parking lot doughnuts? Who let you think you could drive?
Even with Lane Keep Assist, inside the dotted lines, far too many people still weave like drunks.
Starting to get 'older', so I bought blind spot monitor mirrors at a car wash for $5, attached them to the upper outer corners of my side mirrors.
Enough of my ranting, back to you @treehan77.
You likely have a loose HVAC electrical connection, that's the most likely place where a brief buzzing would come from.
Big Mama
Virginia
And an interesting, to me anyway, side note. I recently traded a ‘23 Sierra 1500 for a ‘25 Sierra 2500. It has LKA but no steering correction, also no DFM or auto start/stop. The reason, according to GM, is the electric steering, DFM, and auto stop aren’t reliable enough for HD trucks. It also has an iron block instead of aluminum. Go figure. Everyone should get a 2500. They’re basically the same price.
curbud
