2021 radio screen upgrade
Chickensandwich
I know this has been brought up before, but I’m curious if anyone found a resolution to upgrading the small screen in the PPV? Aftermarket or OEM. The small screen is getting on my nerves. I know the newer models have a real nice screen, so investing in this problem is most likely not much of a concern anymore. I’m holding out for hope. I wanted a bigger screen….
you could check with whites automotive services, just google that
WalleyeMikeIII
Sunny and Snowy Minnesota
Umm ok, and then?
I think it has been said before that the actual radio in the LE didn't have the proper graphics driver to drive the larger screen, you need something beyond the IOR radio I think, what radio do you have?...Rgardless of screen swap, you have to radio swap too, and then beyond that, you have to get the radio to actually function in your vehicle with the other stuff..That is why @Doubeleive suggested contacting Whites, as they specialize in reprogramming vehicles to work (they were the ones that offered the 2022 gauge cluster retrofit in a 2021. But, my net, it is more than a parts swap, and probably will be expensive, if possible at all. I don't recall anyone here saying they conquered it.
White's hasn't conquered it with their upgrade to the Cluster and Google Infotainment either, from their web site:
"Description
Add the factory 2022-2024 Google Embedded infotainment with Navigation to your IOS or IOT infotainment equipped 2021 Tahoe, Suburban or Yukon with plug and play simplicity! This upgrade Is NOT compatible with the base IOR infotainment or the base NON Bose speakers."
See Here: https://www.whiteautoandmedia.com/product/2021-t1-suv-iok-upgrade/
Chickensandwich
Chickensandwich
I saw the prices. For an extra 2" of screen size and HD radio, I think $1000 is better spent elsewhere
johnsonwillie199
