Blowout with Hole in Rim
norcalboon
Northern CA
Wife was coming back from soccer tournament Sunday evening with daughter and had a blowout of right rear on freeway going about 60MPH. She said she thinks she hit a pothole. Check out the damage to the rim - no debris rattling inside the tire. Michelin Defender LTX M/S about 2 years since installed and 30K miles - all have about 8/32 tread left, rotated every 10K miles or so, kept at 35-40 PSI. Never seen anything like this.
jeremiahm
Way North CA
That is crazy. had a similar incident years ago, what ever it was went through the tire and a steel rim. Looked like a .45 exit. It was a country road, walked back up a couple of hundred yards and could not find evidence of what it might have been. Glad everyone is safe.
OBSandaNNBS
Known Thread-jacker
Holy crap, look at that hole in the rim!! Looks like it got punched out. Maybe a piece of rebar stuck in the pothole?
Glad all are safe.
Definitely a road hazard!
With that much wear, replace all of the tires. The AWD system, if you have it, doesn't like the tires being more than 1/8 inch different in height. Sell the old three on Marketplace or the like.
norcalboon
norcalboon
Northern CA
Yessir - I went one new tire shaved to 8/32 from Tire Rack and found an A- rim from SoCal - all in about $600 to replace.
_GMAN_
That's a big hole in the rim. If yor rim is factory, I can probably source you a new one.
petethepug
Michael
SoCal
Lucky, we had all our tire shavers and siping equipment yanked in SoCal.
Probably occurred at a seam on a concrete highway exposing the rebar that was used to join a cold seam of concrete from one workday to the next.
Drop the tire off at the CHP station so the highway team can look for the culprit. If it’s a known and already reported incident you can apply to be reimbursed.
j_jerry79
