03GMCYukonXL
- Joined
- Mar 19, 2023
- Posts
- 149
- Reaction score
- 119
So I have a 2004 Tahoe, and the previous owner before me had a strange valve handle on one of the lines going into the vehicle. If you turned it off and prevented the hot water from going into the heater core the AC would blow cold, if you turned it on it would always blow warm air. The actuator was making a funny noise as well so I replaced it. The one in the lower footwell. I also replaced the hose with one that hasn't been cut and have a valve handle put on it. I have tried resetting my HVAC system by following the ride up on this site by unplugging the fuse, and it still just blowing lukewarm air. Should I replace the other actuator up behind the airbag? I'm not sure which actuator controls the hot to cold blend. Any help would be greatly appreciated
