2017 Tahoe radio jumps around and won’t accept Android Auto - SOLVED
MD1964
I just bought a 2017 Tahoe with the pop up radio. The screen will change radio stations on it’s own and when I try Android Auto, it will Work for about 2 seconds and then goes away.
I just bought a 2017 Tahoe with the pop up radio. The screen will change radio stations on it’s on and when I try Android Auto, it will Work for about 2 seconds and then goes away.
will cost you about $60 and couple hours of your time, dealer will not do this repair they will just sell you a new radio screen for god knows how much and labor will be stupid crazy.
I replaced the one in the wifes rig with this one about a year ago and it's working fine. the video is detailed enough to easily follow along. watch the right side center console re-assembly it has to go back together correctly or you will be doing it twice.
you needs this-->https://www.ebay.com/itm/388626810894?_skw=REPLACEMENT+Radio+Touch-Screen+GLASS+Digitizer+LCD+For+Chevy+GMC+15-18+MYLINK&itmmeta=01JYYSWYD2169G851E8EVYR8PZ&hash=item5a7bf6880e:g:CvwAAOSwTJxoWn-J&itmprp=enc:AQAKAAABEFkggFvd1GGDu0w3yXCmi1du2IDUJ9qyCidffwuzH648cP1pqlsMjBQWjofwGz5uNM***SLA2e1NOIqXUjgCcVj1wObh1O7n1YUBvGt0q56pksKBK9ZyHif9AXehClD+uCihxd34GDmlhM8gDWgqSGxjdG6258hfb/4lzRcCQFwqVc0TToerpJf8qBsrIPwwkSXn13hUxEYbZy8GsrIzSM+EtGKTsnbsZd/VGkspuDrLkOnCH5y9YXGuVyig6ogmqSm7GNm6BzVDKTy23aRy9CceUfWoPQR2GkKVRVkdhhQCdmkeZ2OOZAFTW2unmYLzBShsExTYm1za9QCV24fhZKg7VpRdF12xvrhvjOM0wJ8y|tkp:Bk9SR9zm89n3ZQ
and this is how to do it, I suggest taking photos of the cage assembly once you have it out and on a workspace, because the ribbon cables are fed a certain away, so re-assembly has to match up how it was when removed, just click the play button and it will play on youtube..
M
MD1964
I bought the screen and installed it. It took care of the issue. Thank you for the info
kikeap
