A very common leak point that will take you 10 seconds to check. Take the high and low pressure valve caps off. Put a drop or two of John liquid dish soap on, filling the hole. Bubbles obviously means you have a leak with the valve cores. (Which might only need to be tightened a little bit) You can use the same dish soap on the connections to identify a leak pretty quick. It's the same way you check natural gas lines. Pretty much a zero cost and minimal time check the most common sources of leaks.
PS: the brand of dish soap to use is whichever one your wife uses in the kitchen, LOL. Just don't get caught taking off with it
