Unknown Plug Slots- Total Shot in the dark - SOLVED
Well, weird story but my buddy and I have been pulling a prank war on each other. People have been crossing the line. Anyone have the plate removed from under the steering wheel? These plugs are above where the brake pedal is. Maybe you can even see it with the cover on. I need to find out what goes where.......sort of looks like it does not matter as they are all the same size fuse. Figured i'd ask.
PopoPackage2011
The sockets are keyed and I don't think any are duplicated, so just reinstall them where they fit. You can look at the connector, see the keyed slots, and match those to the connector tangs.
Yep, solved thanks
PopoPackage2011
An update. I got all those plugs in the right way. It seems there is a port with pins in it still (bottom of 1st pic posted) that I didn't have a wire for. Possibly for aux/or some BCM wire?
Anyway, truck starts and runs now all the electronics work- but its stuck in "reduced engine power" mode in which it runs like its misfiring half the time, other times starts and idles up no problems. Also throwing the "Service Stabilitrak/Traction Control".
Any recognizable symptoms from any of you guys here?
Possibly stuck in a CEL situation and just need to borrow my buddy's scanner to clear out the codes? I have not scanned yet waiting for him to have time to come by.....
I am aware the Stabilitrak/Traction warning could literally mean anything. I lost my radiator once, overheated and it was throwing the same messages.
See circled
BadDaddy2003
