L92 engine block with hole
shanerussell
Scranton, Pa.
Hi guys and gals. I own a 2008 GMC Yukon Denali. The block has a hole in it. I'm seeking a block with low mileage. Questions are I seen a 2008 Cadillac Escalade with 70000 miles. Besides the electrical, can I use that engine and just take my stuff off mine and put on that? Is the transmission different and would I need that as well. I'm trying to use my wire harness and ECU. Any feedback I appreciate. Also anyone who has one reasonably priced.
Exactly the same, both used the L92. It's plug and play as your drivetrains are identical. The Cadillac in that year had the engine tuned for 91 octane and 403 horses, yours is tuned for regular gas at 380 horses. Swapping the engine and keeping your computer won't change a thing, good. Good either way.
If that doesn't work out, any L92 or L9H or even an L94 will work with your existing harness and ECM. Try to stay with the first two and avoid the third unless the price is too good to resist!
shanerussell
shanerussell
Scranton, Pa.
Thank you so much swathdiver. I appreciate you knowledge. I wanted to delete the dod to put in a stage 3 cam and double springs on my 823 heads. Just to increase the horsepower. So when I do get it out and get a engine. I'll keep you in mind to assist me if that's ok.
It is a shame to read that you have a hole in your L92 block. That is a wonderful motor, and often finds itself in the hands of the racing crowd. I don't believe that the 2008 Escalades had DOD, so you won't have to delete anything.
petethepug
Michael
SoCal
07 & 08 are L92. 09 is L9H. None have AFM/DOD. In 09 GM changed the fueling system and injection system to accommodate the (09-14 specific) larger injectors for flex fuel.
The 07 & 08 Yukon Denali, Sierra Denali and Escalade all run the exact motor you need. ****** that 08 Escalade motor. The trans is an exact match too. If you like the interior, most of it is a direct swap.
Warriorpluto
So ive been running premium 93 in my 2007 denali for nothing? I thought these were required to run 93? If this is true, this is why my catalytic converter is clogged now
Marky Dissod
... both used the L92. It's plug and play as your drivetrains are identical.
So, the difference between the two L92s is in the GM OE tune?
Does the exhaust have anything to do with it?
donjetman
You get about 20% better gas mileage running 93 vs 87.
Premium is recommended, not required.
I've run 87, 89, 91, 93, and E30 in the 6+ yrs I have had our 07 Denali w/L92.
nope, some other reason did in your cat.
petethepug
Michael
SoCal
07 & 08 Denali (6.2L) have a gas door sticker for 91 recommended. GM detuned them until 09 to differentiate (sell) them from the Escalade.
89 is alright for highway cruises. I always ran 91 (CA) because I had a buddy who cracked a piston running 89 in his RX300 on mountain roads.
Cats can clog from a hard hit of road debris breaking the ceramic honeycomb up or bad tune from intake, exhaust leak, etc left unchecked.
@shanerussell any luck on finding a new 6.2L yet? The L96 6.0L from the trucks and Burb 2500 is a drop in option too.
rdezs
If your catalytic converters plugged, it's usually due to contamination from oil, fuel or coolant. You'll want to find the source before you spend the money on new catalytic converters.... Or they will suffer the same fate.
JeffK
