$5,540 up-charge for the Diesel
Protect1989
Playing around with the 2025 build configurator and it shows a $5,540 up charge for the diesel engine on the Z71.
On the build calculator for a Silverado ZR2, there is only a $1,965 up charge to the diesel.
Do we think the $5,540 Diesel motor premium is legit or will that come down in time? When using a fuel calculator, it would take over 7 years to recoup that cost compared to the 5.3!
Silverado4x4
Probably take longer than 7yrs to recoup the cost due DEF fluid, oil changes are higher plus fuel filter replacements. I figured it up once with the up charge and difference in mpg vs the 5.3 and Diesel plus extra price of Diesel fuel price it was more like 12yrs or so. Alot of people buy the Diesel for mpg and don't think of the extra cost just for the motor and think there saving money. They also say it has a higher resale value of course it does but you payed the higher resale price when you bought the vehicle so it really doesn't.
For the ZR2 there is a up charge for the 6.2 over the 5.3 so that's why your seeing less of an up charge for the Diesel vs the 6.2.
P
Protect1989
It seems the pricing is all over the place. Looking at the LT, its a $500 increase to go from the 5.3L to the 3.0.
Not sure how chevy is determining which trims get such a drastic increase for the diesel compared to others.
I would love to get a diesel Z71, my sierra AT4 has the 3.0 and the fuel economy has been incredible. At $5,540 it doesnt make financial sense to choose it. Now if it was 1-2k, that would be a different story
Micahsd
I’m not sure what to make of the pricing. I think they’re getting way too greedy.
My ‘21 Premium today would cost about $10k more to get the same options. There’s a really sweet ‘25 RST near me with the RST performance package but it’s sad for $80k it doesn’t even have cooled seats.
P
Protect1989
The fact that you can not option a 2025 RST or Z71 with cooled seats is insane. You can get those options on a Honda that is half the price!
pa31p
You sure it’s just the motor? not some other added package that’s required with the duramax?
Appearantly the Duramax may be a while yet and allocation is close to
maxed out for april/may. I believe it as dealers paying premium $$ to trade a 2023/2024 duramax in.
Hobert
Downers Grove, IL
Changes are more than engine. Z71 diesel was not available on 2021 thru 2024. Note below
The Z71's unique front fascia, designed for better approach angles, caused issues with the diesel engine's intercooler and piping, preventing it from being offered on this trim level.
Stbentoak
Lots of people have been brainwashed about how expensive it is to have and maintain a diesel. They act like it's a hydrogen engine or something.. I can change my oil, fill the DEF, and change of fuel filter All in less than an hour and for under 100 bucks..... And be good for a year or longer in the case of the fuel filter...
The diesel on my current Denali was actually a fifteen-hundred-dollar credit. Was also on the 2025 I ordered. Diesel Yukon's and Tahoe's rarely sit for long on a dealer lot as they are the only reasonable proven alternative to AFM/DFM issues, Lifter issues, and engine replacing main crank bearing issues. I never get less than 20 mpg in the very worst stop and go traffic and usually average 27 in normal driving. Diesel is also cheaper than premium by a long shot.
Would I pay 5k extra for it? Probably not...But then, again, thankfully I'm not interested in those trim levels that require it....
P
Protect1989
Positive. This is the beginning of the build configurator, before you even get to the options section.
pa31p
What i’m saying maybe they’re adding packages as part of the diesel option.
P
Protect1989
Funny enough it’s the exact opposite. You can’t get most of the packages with the diesel including the air suspension or tech package.
Build out a 3.0 diesel and try adding any package, it makes you go back to a 5.3
pa31p
In that case. you can burn a lotta gasolina for $5K. i’d pick the 6.2
olyelr
Elk Rapids, MI
I guess thats better than the $12k cost for the cummins in the ram trucks.
Last time i played around with building a gm the diesel was cheaper than the 6.2, but that was a while ago.
Padraig
Army
WOW! When I bought my 2023 Suburban LS, the Diesel was just under a $1,000 option. That was a no brainier.
Padraig
mplunk
Adding the diesel force adds the Comfort Package and advanced trailering package vs both of those being an option with the 5.3. That's $2,725 of the increase, plus it adds the power second row bench seat for $370. So $3,095 are added packages and the diesel itself is a $2,445 up charge. Still a big price difference but not as bad as it seems.
I may have missed something else that gets added as well
P
Protect1989
Good to know. Annoyingly you cant add the air ride suspension or the tech package for the diesel (dont know why)
DuraYuk
In the refresh the diesels are being paired with super cruise...as the only way they can be optioned the price increase is from that pairing
jerry455
It was around$9,000 for a Duramax in the heavy duty Silverados.
DaveL
I think when you change it to the diesel, they add a bunch of packages at the exact same time.
If you look at the diesel on the high country, it is not that much more because the high country already has a bunch of those packages built into the price.
I'm waiting for some to hit the lot to see what the final price is.
dukecharmary
I did a build at the dealer last month for a denali duramax. This option added supercruise tech package. But said the system would not accept order and probably be March
justafarmer
