Can you help me with OBDII code: P0430 ?
Eschrichtius
Just an update, still no CEL code. Everything's working great and MPG is back where it supposed to be :)
kingbilly68
Bringing this thread back instead of starting a new one. My wife's 08 Yukon threw a check engine light yesterday. Scanned it and got a p0430 code. Is the O2 sensor still the place to start? Or should I plan on a cat? Thanks.
Beeker702
Buffalo ny
I’ve been fighting P0430 for weeks now on my 2015 Tahoe . I’ve replaced both cats and all 4 oxygen sensors as well as all coils, plugs and wires. Cleared code and it comes back a couple of days later. Truck runs fine just have no clue why it won’t stay off for good. Had the fuels trims reset and that didn’t work
There are several reasons for a P0430. The most obvious is a failed cat, even a new one. A large exhaust leak can set the code, such as a leaking exhaust manifold.
Aftermarket cats and O2 sensors don't play nice with the computer and they will set varying codes.
Finally, when the troubleshooting guide has been exhausted, it's usually time for a new ECM.
A new cat will often set a code within the break-in period, usually a hundred miles or so.
Beeker702
Buffalo ny
I’m told by dealer that the o2 needs to be programmed after being replaced
j91z28d1
it's been talked about here. technically you could call it that. the o2 has a heater circuit in them and the ecm controls that with a pwm ground circuit. it needs what's called a heater reset.
but unlike normal module replacement that need progammed using gm's dealer software. when you clear the codes with a standard obd2 scanner it clears the heater data and the ecm goes thru a recal automatically.
the annoying part is the o2 itself. 99% of trucks will be fine with any old brand o2. but some seem to not work correctly with anything but oem. and not even ones made by denso, which is believed to be the oem manufacture of the gm part, but the actual gm part number o2. why, I don't pretend to know and tons of people can throw any old cheap auto parts store o2 in them and never give a 2nd thought. others it seems to be an issue.
Beeker702
Buffalo ny
Yea denso is what I put on my truck. Truck runs great but the damn light won’t go away. It’s being “reprogrammed” tomorrow so by Friday I’ll know if it worked or not. I live in NY and been trying to get my truck inspected for almost 2 months with no luck because of that stupid code. I can look at live stream and everything reads normal, even when the check engine light comes back on. So I’ll post back Thursday or Friday, if it makes it to Monday then it’s getting inspected
j91z28d1
I'm interested to know what they tell you. ask questions if you can.
when you say you had the fuel trims reset. what does that mean? not sure I've heard of that in this context. it's something that's done during tuning with programas like hptuners.
donjetman
Almost 2 yrs ago at 192k miles I changed all four of the original good working O2 sensors in nour 07 6.2L with: 2 new GM Genuine # 213-3533, $58ea, & 2 new GM Genuine # 213-3538, $53ea, all from amazon. I keep the ole ones for spares. Same goes for the knock sensors. pt# 213-1576.
Beeker702
Buffalo ny
They refreshed the computer, they were finally able to inspect the truck and it passed but the damn light came on Thursday night with the same code
j91z28d1
this isn't exactly the same, since his was a rear o2 code with denso. but just for info.
Beeker702
Buffalo ny
They flashed the module and was able to finally inspect and pass inspection but the damn light came back on Thursday night still with the 430 code. I tried some things with my scan tool since I updated some of the software on it. We shall see if what I did worked or not in a few days
Beeker702
Buffalo ny
Check your fuel trims. If you can’t then disconnect the two hoses that goes from valve covers to the air intake. Clear the code and drive to see if it comes on, if it doesn’t then it’s your high pressure fuel pump located under the intake
CKendrick
