overall design varies on some clusters like the notches/markings, for instance the ppv cluster has different markings and shows speed to 140 and the hybrid shows battery economy, etc
but you will not "gain" anything that your trim level does not already have, even if you swapped one in without programming it to the vin it may show some things from the trim level it came out of but they won't do anything.....
once it is programmed to your vin it will do the exact same thing your existing cluster does
if you want more features you have to add them, say like power fold mirrors, etc
if you just want a different look that's what you get
I could be mistaken but I don't think they "added" any features that could be performed specifically thru the cluster from 07 to 08 or any other year
the ppv's didn't come with a dic switch but the connector is there and the switch can be added giving the ppv access to settings that "already existed" but just needed the switch to make it happen.
