Beefed up suspension
dadwagon95
Asheboro, North Carolina
What's up everyone, new to the forum and glad to be here Ive always been the one reading them and looking for specifics but I figured hell w it and registered for an account. Anyway, I drive an 04 GMC Yukon 4x4, 258k miles, (no lift that Im aware of) I have been dappling in tire/wheel trade. Long story I ended up with a set of 20x9 gear off road gloss black wheels with 265/70/20 Toyo open country a/ts on them. According to my tape measure they're 32"... I'm still on stock suspension I believe (only had the truck about a month or so) and from what I've researched the stock suspension will end up giving me issues with this size tire.. any suggestions? Again I'm not sure if I have a lift already nor am I sure how to identify it. There's no dead give away and with taking my fender liners out I have no rubbing
S33k3r
Dallas, Texas
I made the mistake of measuring a set of wheels with a tape measure as well. The "actual size" of your tires -- no idea how it's calculated (maybe tire size and required clearance?) is 34.6" -- almost 35". That is never going to work without rubbing, a LOT of trimming, or a lift. 33" is right at the limit for standard height, may require a little trimming, and assumes a working stock height suspension.
Here is a tire size calculator, maybe it can help: Tire Size Calculator from Tiresize.com
I don't necessarily think that your new wheels/tires will cause any rubbing problems. Put one on a front wheel and move the steering wheel from end to end, and look at the clearances. I run running 305/50x20 tires with a 32" overall height, and I have no rubbing issues (close clearances, yes, but OK). I recognize that I have a GMT900 model, but I think that you'd be OK with your GMT800 model.
S33k3r
Dallas, Texas
My '02 Z71 wears 255/70R18, which are 32" tall. No issues, but it's close enough.Try a better tape measure. 265/70R17 are 31.6" tall, so 265/70R20 MUST BE 34.6" tall.
Ok, I must be doing something wrong. I measured my wheels and they came out an inch or two shorter than the tire calculator said they should be. Even accounting for wear they were way off. I have a customizer friend, and he said that is normal. So a tire that measures 32" with a measuring tape is likely to be considered a 33" tired.
Please don't make me go out in the Texas heat and check myself...
dadwagon95
dadwagon95
Wowwww now I feel dumb. Welp. Back to the drawing board lmao. Fortunately I actually don't have any rubbing which is surprising because I don't believe I have any kind of lift on this Yukon
dadwagon95
dadwagon95
Saying I thought they were 34s but I just wasn't sure for some reason I felt like a regular tape measure that popped up 32 inches tire height was the size that I had but I was really stuck at they were 34s
dadwagon95
dadwagon95
It's my question is how is your tire size bigger than mine and only has a 32 inch height everybody on the other post that I made are telling me I have 34.6 is almost 35
S33k3r
Dallas, Texas
Perhaps you can go to the link I provided, or even Google "tire size calculator" if you do not like the one I suggested. The one I use has a second function that lets me compare tire sizes, so I can get the right wheel+tire combination for the size I want to run. That also lets me research to see if the brand/model of tire I want to run is available in that rim+tire combination.
02Richguy
What width can fit with the 33s?
S33k3r
Dallas, Texas
285 mm, or so I've been told. But I don't know what offset that would require, if any.
Towmaster
