Front air dam ??
Ont240
Ontario
Is there an air dam add on for 07 Tahoe LT 4x4?
I'll try post pics.
Mine has a thin support abs bracket at the bottom. Appears to be part of the bumper cover. Is it missing something. Bought the vehicle used like this. Need to improve aerodynamics. Has any one tried to create a diffuser at the back?
Ont240
Ont240
Ontario
does it clip in at the top and then gets fastened in a couple of locations.
I could add to its depth with a rubber strip and reduce the air going underneath.
Maybe remove the cross bars when not using the roof rack. Still used as a hauler sometimes!
Marky Dissod
Use the lower bits from an '08-'13 Tahoe Hybrid, like Doubelieve above.
For a budget approach, trim lawnmower edging to the desired shape.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
@iamdub has to watch his, sometime lays frame with it, can't find the damn pic he posted.
keithcruiser
I'll try post pics.
.View attachment 428990View attachment 428991
As a retired pilot, I don’t think aerodynamics are going to make a difference to a Tahoe. My ‘81 Suburban could plow through deep snow with it’s chrome bumber. By the time I bought a 2018 Denali, the air dam was so low to the ground it scraped parking curbs and dragged in any snow accumulation, particularly on rutted side streets. I finally cut 4 1/2” off my airdam with a jigsaw and now have a much more snow capable vehicle that looks better.
Marky Dissod
... don’t think aerodynamics are going to make a difference to a Tahoe.
Compare MpG cruising @ 60MpH vs cruising @ 70MpH, think again.
Some people don't care about the difference; that'd be the difference between ignorance & indifference?
Insouciance?
It really is too bad the fronts of vehicles more closely resemble walls, than the front of SnowPiercer ...
fozzi58
North Jersey
I'll try post pics.
Looking to do one myself. I was thinking of using my bumper to to make a mold out of cardboard and FG and see if I can design it like the ZL1 or something.
steve45
I cut about an inch off the bottom of my 2016 Tahoe's air dam. Got tired of damaging it on curbs.
Fred34
I removed mine because I kept hitting it on rocks.
No difference in mileage, due to many other factors. Heavy foot included.
I have the same SETINA push bumper on my 2015 PPV Suburban, and I actually took the lower air dam OFF, in order to improve the wind resistance issues and also to make the truck look a lot sleeker !!!
BadDaddy2003
